72" span Avro Shackleton
22 Mar 2017 20:35 #16 by Squirrelnet
Replied by Squirrelnet on topic 72" span Avro Shackleton
Looking good Tony... Interesting hanger space you have under the table
22 Mar 2017 20:54 #17 by Ex-Member
Replied by Ex-Member on topic 72" span Avro Shackleton
That's just the two i fly , the rest are in the hanger.
:P
23 Mar 2017 19:26 #18 by Ex-Member
not much to report today.
i have been making spars for the centre section and cutting out the outer panel cores.
pictures will be taken tomorrow...i hope.
24 Mar 2017 19:24 #19 by Ex-Member
Plodding on.
need to cut wing ribs over the weekend and then wait for the motors to turn up.
Tony plodding on slowly B.
24 Mar 2017 20:51 #20 by Squirrelnet
wow its at the 'proper aeroplane' stage already , very impressed. Unmistakably a Shackelton even in this state
24 Mar 2017 22:55 #21 by Eric
Replied by Eric on topic 72" span Avro Shackleton
It's almost the right colour for a 'tropical' shack, too! :P
27 Mar 2017 20:09 #22 by Ex-Member
Got a little bit more done today between all the other jobs.
front dihedral braces made and some ribs and a little bit of sheeting.
We plod on slowly
28 Mar 2017 18:27 #23 by Ex-Member
built the elevators today and glued the wings together.
we plod on slowly.
29 Mar 2017 18:10 #24 by Ex-Member
Drew up and cut out the 6mm ply nacelle cores today.
jigged them all up and glued them home.
tomorrow i am hoping to fir the motors and esc's...fingers crossed.
little shot of the 72" span version with the nose of the future 144" span model. ;)
Thank you for watching.
30 Mar 2017 13:08 #25 by Ex-Member
should have made this the same scale as the TN 72" Lancaster or 17th scale.
an 84" span version would have been easier to work on than this 20th scale version.
30 Mar 2017 20:38 #26 by Ex-Member
Just designed and printed off the first of four nacelle fronts for the mini shack.
will have 3mm Depron clad round the outside and should allow plenty of air flow to the motor and esc.
Tony Shackleton B
31 Mar 2017 18:59 #27 by Ex-Member
all four cowls printed and now stuck on, i need to open up the backing plates to match the air intakes next.
but we plod on slowly.
31 Mar 2017 21:24 #28 by Squirrelnet
Those elves have been very busy Tony, nice work
Time to create page: 1.046 seconds
