cut the last 3 fuselage formers, a nice long job what with all the notches for the stringers.
then i started the first of the stringers.
i will do as many as i can with the fuselage jigged up, then by the time it has to come off the bench to have the rest done it should be rigid enough to handle and finish off.
worked ok with the last 4 i did.
next job is the tailplane (or i could start another project)
- blue123
- Thank you received: 146
- Flytilbroke
- Thank you received: 1987
It seems strange it does not use the scale section Clark YH. Easy to build with a true flat bottom area like the Clark Y but with a slight swept up trailing edge.
