- Thank you received: 14473
I would be very surprised if the YH produced any more drag than the section Tony is using.
I have seen an article giving the results of some model size wing tunnel tests that showed the benefit of more modern sections (using the same chord to thickness ratio) over a Clark Y was limited about 5% at best L/D and not much more at high speed. Significant for a high performance glider but it would very little difference on a scale power plane.
The reason given was the effect of the relatively thick boundary and high viscosity (low Reynolds number) tended to swamp the true aerodynamic properties of the specific wing section.
This sort of thing could explain why the 'stepped' Kline–Fogleman airfoil sections are considered so good for models whereas NASA and others could find no benefit (but rather a penalty) in full size.
as i did nothing yesterday, i thought i better do something today.
need to sand the top down next and then sheet.
then i can work on the wing to fuselage fairing and make the wing tips.
need to order some retracts from HK over the weekend so i can get on with the underside of the wing next week.
it's starting to take shape now.
- soloslogger
you would not think that there is only 20 years between them in design.
it will be finished one day. then i can get on with something else
Looks like it fits and lines up as well. phew.
so tomorrow i can sort out the servo trays for the fuselage and wings, then cover the underside of the wings as far as the center section.
then once the retracts turn up i can finish the wing off and move onto the nose area.
nose is covered and ready to be cut off and trimmed and the mounts making.
Top of the wing is fully sheeted, i have l/e to shape and the tips to do.
underside of the wing has been sheeted to where the u/c goes, u/c mounts are in.
tail plane and fin have been glued together and are ready to fit to the fuselage.
Sorry Tony, couldnt resist it mate
