E-Flite Mini Pulse
- Thank you received: 14305
Have you run the motor at full power with a WATTMETER in line?
I'd have put the 80 amp speedo in. If you have too much power available, it won't blow up in flight! Don't forget - if the speedo fails - so will the bec, and then the radio won't work either.
My 40 amp speedo carries 400 Watts at full chat, and is a bit marginal, but as the model only needs 250 Watts for dozy flying, and 300 for aero's, it is only working hard for about fifteen seconds - for take-off.
Well that will teach me not to post till I have checked. The PNP version has a 22 A ESC installed, and we are saying 25 A is too small ???? However, my advise stands. Look at the one that has failed and replace with same.
As I put, a WATTMETER will tell you just how much the motor/prop/battery combo is producing, and as a more powerful speedo is a mere few grammes heavier - - -
Draw your own conclusions.
However, this does surprise me on here with the eagle eyes we have, that no one has noticed the error on the header of this thread. It isnt a Hanger 9 product, its an E flight product
H9 vs Efright - I hadn't looked it up on the shop listings, so I didn't notice, Garry!
