Blohm & Voss P.215
Knowing that the Outerzone offerings were free I went there first, and found the P215, which to me is such a pretty aeroplane, it was originally designed for some kind of rocket/Jetex motor but surely a small EDF could be persuaded to fit! And at 18" span not too small for old eyes.
I duly downloaded the PDF files and, yup just the job. The wing section will even give quite a bit of lift and could be modified to give more if she gets a bit portly.
I printed them out (2 pages) then discovered the check measurement bar at the bottom measured 60mm instead of 100mm. I then went back to the printer options and told it to print actual size, great, except that I now only have about 1/4 of page 1 & 2. Help needed please.
looks a interesting project though, following with interest, incedently the rocket motors, rapists, are now available again..still tempted by a V1.
quite like the shape, please make it ff Klippy.
Have a look at this site, loads of info on mini edf jets etc, the guy who runs it ( Mike) is a genius and very willing to help out with advice.
www.ffscale.co.uk
The trouble with FF Paul is my open space is littered with thorn trees, and any uncontrolled landing is bound to find one, ask me how I know! The other problem is, when they cut them as bush encroachment control they just leave the cut branches and stuff on the ground! They claim it allows the grass to grow underneath without being cropped too close! Crap! Sadly we often see game limping because they've walked on this stuff!
Won't weight be an issue?paul d wrote: Double cover it Klippy, polyester silk and dope with tissue over the top is bomb proof ( well Heather and gorse!).
I do have some silk that I bought as part of a covering system for my Hawker Fury (which probably won't ever get built.
You should know the old saying, Tony -
one year's seeds, ten years weeds.
which was the most produced and effective jet fighter ever. I wonder why that might be.and likely spawned the Mig 15
Ah! the Swallow. Undoubtedly a very pretty plane. 3 were built but all ended in fatal crashes. Eric Brown flew it and survived a transonic buffet event simply because he was short, sat lower in the cockpit, so avoided repeatedly banging his head on the reinforced canopy. The first 'low speed' prototype actually crashed last of the three from a non recoverable inverted spin.
You are quite right to be concerned at weight. All EDFs need a relatively high battery weight simply to deliver an appropriate thrust. For small EDFs its even worse. The saving grace for free flight is the powered duration is short allowing a smaller but even harder worked battery to be used.
