- Thank you received: 215
PB Models Crescent Bullet
- RobC
First off, the wood selection and cutting are 95% perfect, the only error so far is that the wing chord is 1/4" greater than the wing cut-out so the trailing edge needed a trim in the centre section. I also beefed up the 4mm ply bulkhead with another layer of 1/16" epoxied on as it just didn't look right.
Yes, in two very casual evenings and a wet Saturday this kit is half done - foam wings built and joined ready for a f/g bandage, fuselage sides doublered, edged and joined with the two main formers, closed loop exits and elevator snake installed ready to accept the front bulkhead, fin and tailplane parts assembled and lots of balsa shavings (and dust!) generated.
I'm going old-school with a single aileron servo and torque rods, but using Corona 339 MG digitals all round on 6.6v.
I did look at making it leccy for all of 5 minutes but an OS 40 FSR won the day.
Pictures may follow...
I'm greatly tempted to leave the rudder and elevator trailing edges squared off, it's one of those jobs I dislike intensely is tapering 1/4" balsa, anyone know of a downside to this on a fast model?
will interesting to see how you get on with it sir.
tony.
Have you seen the dual blog on here regarding this version?
www.modelchat.org.uk/forum/thecafe/31234...t?limitstart=0#38502
Where drag is of great importance (full size gliders and airliners) very fine trailing edges are used and it would be fair to assume they do this for a reason.
- Inactivated User
- RobC
- Phil Wood
- Inactivated User
I'd add the weight for the maiden & make it nose heavy. Each subsequent flight after that, take off a bit of weight & lose some of the "UP" trim..... Just do this in stages until is does become too sensitive for your liking, then put that little bit of weight back on if needed.
You'll probably find you don't need any weight after all.... but I'd much rather have a docile model for the maiden, then when all the other trimming is done & you're happy that the surface throws & any expo etc. is sorted,... finish off the COG to your liking.
- Inactivated User
- RobC
I've always wondered how people manage to state or measure a Cof G with such precision. Maybe I've just got stubby fingers? Use pencil points and then you have to ask at what exact angle of incidence should the model rest?
In all honesty I've only known two models where the CofG really was that critical, both of them flying wings. Real bicycle clip territory with the slightest degree of tail heaviness.
- Inactivated User
- RobC
That's my point Alan, just the width of your fingertips gives 5mm or more latitude, then there's different peoples interpretation of 'slightly nose down'. Unless the centre of mass lines up with the wing upper surface this can add a few more mm variation into the mix.alan cantwell wrote: Always inverted, with just the tip of the finger, and a correct cg is very important, It's perhaps the most critical measurement on any aircraft, Bullet CG is 80 mm from leading edge at the root, inverted, slightly nose down, empty tank, or in a lekky version, with the batteries in flying position
Anyway, thanks for checking as that confirms I'm within 5mm now.
- Thank you received: 10722
