PB Models Crescent Bullet
- Inactivated User
RobC wrote:
That's my point Alan, just the width of your fingertips gives 5mm or more latitude, then there's different peoples interpretation of 'slightly nose down'. Unless the centre of mass lines up with the wing upper surface this can add a few more mm variation into the mix.alan cantwell wrote: Always inverted, with just the tip of the finger, and a correct cg is very important, It's perhaps the most critical measurement on any aircraft, Bullet CG is 80 mm from leading edge at the root, inverted, slightly nose down, empty tank, or in a lekky version, with the batteries in flying position
Anyway, thanks for checking as that confirms I'm within 5mm now.
You have to have some levity here, anything over 15 lbs tends to make the fingers sore, but use a surface that's too small, and you could damage the structure, The middle of your index finger will do, and slightly nose down is just that, slight, that's easy enough to interpret, surely
- Thank you received: 10722
- RobC
- Thank you received: 215
The nose leg is 10cm from the bottom of the fuz to the axle, and the span is 58.5" or 148.5 centipedes.
