Wots Wot foamie
It arrived the day before I had to go to Pretoria to repair a roof so has sat here waiting for me to get back.
- Thank you received: 14141
The Ripmax legend had been blanked out.
All very nicely protected
All excellent quality pressings/extrusions
Washing of hands is very necessary before starting a build session!
- Thank you received: 10572
Im sure you will enjoy the Wots it though
Anyway I started by fitting the tail plane and immediately ran into a problem. The keeper for the push/pull rod was binding on the horn
A little work with a file sorted that.
Next up was I had lots of up elevator and relatively little down.
The inner Bowden tube had been left overly long, once shortened I had plenty of movement.
There's no glueing at all, it all just screws together with instructions in both English and German, the fit and finish is excellent. At this point I fitted a receiver and found the servos perfectly zeroed. I also added a small piece of tubing as belt and braces to the elevator keeper.
Probably not necessary, just piece of mind.
So much better than the Funcub which is glued in and detaches every time you ground loop.
Last is the undercarriage
It's not obvious which way round it should go so I opted for the wheels as far forward as possible.
That completed the fuselage section and so on to the wings,
2 servos, 1 plug! and how short is that cable, definitely not fit for purpose, without differential on the 4 (yes read it, four) ailerons the adverse yaw must be huge! I cut off the starboard servo wires and crimped on a new plug. (Port ailerons always go to channel 1, Starboard to channel 5 or 6)
We're now ready to mount the wings
The upper ailerons are connected via 2mm push/pull rods.
At this point I did a power test, 200watts on a storage charge 3S battery, at 2.42lbs that just over 80watts/lb, hmm, hardly electrifying!
Did I have to say that?
At this point I decided to have a good look at the front end, maybe go up to 4S?
Access is easy, you take the nose cowl off (2 screws) and everything is right there
Quite a lot of side thrust
That looks like up thrust to me, I've measured carefully, assuming that the cowl is square to the thrust line the motor mount is exactly square.
The motor carrier is a very nicely pressed piece of steel plate, 2mm thick
Moving the motor forward or back (more likely) should be easy
- Thank you received: 19042
If you need lead, don't put it in the spinner, unless it is perfectly balanced in rotation, that will stress the motor bearings!
If I recall, the metal motor mount is screwed to a small ply plate which is glued to the foam. Any oscillating mass on the bearing will quickly weaken the foam to the point where the motor goes it's separate way.
- jon.in.swansea
- Thank you received: 1147
also give you a bit of weight forward?
However, as Jon pointed out, the wheels might be a bit small so I'm going to change them for those from a long since crashed Focker Eindekker
