- Thank you received: 41
- Forum
- Forum Categories
- Phoenix Flight Simulator, Settings & Adjustments.
- Phoenix - Connection Issues / Can't see some users
- Walrus
- Premium Member
- Smile it makes people wonder what your up to
04 Jul 2012 01:03 #16
by Walrus
Replied by Walrus on topic Re: Phoenix - Connection Issues / Can't see some users
4.0k yes I recieve the updates auto. It was just a thought.Garry Pollard wrote: Is it 4.0 or 4.0k Walrus. You can set it to update automatically.
04 Jul 2012 01:05 #17
by Garry Pollard
Replied by Garry Pollard on topic Re: Phoenix - Connection Issues / Can't see some users
Then you should have no probs. I have the same setup and dont have any trouble
- Thank you received: 14141
04 Jul 2012 02:28 #18
Replied by Eric on topic Re: Phoenix - Connection Issues / Can't see some users
Because the new format doesn't allow punctuation marks in the title, look for sites listed as modelchat dot org dot uk (then someone's name).
- rambo
- Premium Member
- Thank you received: 187
31 Oct 2021 17:07 #19
by rambo
Replied by rambo on topic Phoenix - Connection Issues / Can't see some users
On this software can you fly a Lancaster and can you connect the RC control s the ones you would fly with
31 Oct 2021 17:30 #20
Replied by Eric on topic Phoenix - Connection Issues / Can't see some users
I haven't used it since 2012!
If there is a Lanc in the model list - then yes. If not - no!
Using your own tx - if there is a suitable connection between your tx buddy socket and the dongle, probably yes.
- Flytilbroke
- Thank you received: 1969
01 Nov 2021 09:04 #21
by Flytilbroke
Replied by Flytilbroke on topic Phoenix - Connection Issues / Can't see some users
Phoenix model flight sim is no longer made or supported. However the Software is readily available as are cloned Dongles. The is at least one group of users still active although I did not keep the details. Should you go for a copy make sure you get what was the latest version 5.5. It works well with the older Futaba or Spektrum Transmitters as controllers. I still consider it as the best model flight sim. There was not an official Lancaster that I am aware of. Some user designed models and flying sites are better than others
01 Nov 2021 10:05 - 01 Nov 2021 10:06 #22
I think the one I had was a cloned rip, but it worked ok. Some of the other sims on the disk didn't.
I might excavate it from the junk-heap, and see if it will run on W10. Last time I used it, I was on XP!
Last edit: 01 Nov 2021 10:06 by Eric. Reason: added a comment
- Dragonfly
01 Nov 2021 12:55 - 01 Nov 2021 12:56 #23
by Dragonfly
Replied by Dragonfly on topic Phoenix - Connection Issues / Can't see some users
Phoenix flight sim does work on Windows 10 Eric
Here is a link for the downloads.
www.rc-thoughts.com/phoenix-sim/
Last edit: 01 Nov 2021 12:56 by Dragonfly.
- Flytilbroke
02 Nov 2021 08:57 #24
by Flytilbroke
Re Phoenix website info. Thank you for that.
- Dragonfly
02 Nov 2021 11:27 #25
by Dragonfly
No problem Flytilbroke
- Forum
- Forum Categories
Time to create page: 0.310 seconds
