Basic model
but that would mean building a new fuselage and i am almost out of material.
- Doug
- Senior Member
- Thank you received: 84
Tony B wrote: i think the arse end is too fat, needs thinning down a touch me thinks.
I think the tailplane/fin are too small which gives the illusion of the large rear end. May look better with the elevator fitted but the fin definitely needs enlarging.
Doug
Given that the model is made of Depron, it's a trainer and it's going to take some punishment, so the back end being a little deeper than it should be is a good thing. The larger empennage will also add stability, which is also a good thing for a trainer.
Well done mate!
fitted the rudder and elevator snakes as well.
so if i get time tomorrow i will finish sheeting the top of the fuselage.
need some wire for the u/c and a battery box next.
will leave the front open until after i have fitted the esc and u/c.
so i need to sand the edges round and i can cover the fuselage and make it ready for paint.
fitted the rudder and then glued the tailplane/ fin ensemble to the fuselage.
i also fitted the wing dowels.
need some wire for the u/c now and we can finish the fuselage off.
i have more depron coming on Tuesday ( i hope) so i should be able to construct the wing next week.
soon be finished and i can then start the next daft idea.
