- Thank you received: 680
TN Vampire
- Si_B
Plans - Christmas present from the wife
Turbine - Wren 80 kero start (sitting in its box for the foreseeable)
Retracts - ordered from Kingfisher aviation (4 weeks lead time)
Wing tubes - ordered from Phil at fighteraces (these work out quite expensive!!!)
No sure about servos and stuff yet, had loads of emails from people building or finished models to think about during my build. This will be my first scratch build jet and I'm quite excited about it. Got a load of wood already, so need to have a good look through and see what else I need to order. Going to start with the tail and the booms.
Simon
but turbines are way out of my price range.
- Si_B
All my turbine stuff is used pretty much, but I really want to build my jets. The Vampire is first, then a Ziroli Panther and TN turbine Vulcan is on its way. I still want to build a Hunter like BB's on here.
Simon
- Thank you received: 10615
- Si_B
I will make sure mine balances at the same point !! I think I'm going to go for the same paint scheme as Tony did on his original model.
Cheers,
Simon
- Si_B
- Si_B
- Si_B
Got to say, I'm really excited about finally starting my build and having a new toy to play with. Used to teach CAD design before I left to go into teaching. It's been fun doing the CAD work, even though the time invested in converting from the paper plan far exceeds the time it would take just to trace and cut out by hand.
Needed two of each as they need to be 6mm lite ply and I've only got 3mm.
Simon
how hard is it to convert cad into cam for cutting as i want to head that way myself in the near future.
You saw the one built in the jet mag by a very experienced builder and it went in on its maiden, totalled
It was only 2/3 mm behind the recommended C/G but was unflyable
- Si_B
I have read a few build reviews on this including the ill fated one in the magazine. I'm going with a single elevator servo and closed loop rudders to keep as much weight as I can off the back. I have been warned about not going behind the stated c of g.
Going to model the rest of the formers tonight and then see if I can get the plan scanned in to convert the wing ribs into 2d tool paths so I can cut out using the laser cutter.
Will post as I go along.
Simon
The Beard wrote: interesting but it all goes over my head
If it does that and you are flying it Stephen , you are usually heading for a crash
- Si_B
Need to keep the weight to a minimum at the back, so I've found my lightest piece of 3mm balsa to take to school tomorrow to try out on the laser cutter. Will post some pictures tomorrow.
Still got my Grumpy Tiger Cub to finish off but might build the tail plane to practise my technique with glassing. Lots of new skills.
Simon
