- Thank you received: 680
Pilot RC Dolphin
- Si_B
Was hoping to just put my turbine in as model has been built with servos etc, but after finding a few things I wasn't happy with (servo wire glued to thrust pipe) I decided to completely strip it and start again.
- Si_B
Pipe had to come out to get the excess glue of and I was not keen on the method being used for connecting the air and servos to the wing, so all the wiring was taken out as well.
Then I removed the rudder servo cover.
Not a good idea to use super glue on such dense wood. Now expoxied and and additional screw through into the blocks for security.
- Si_B
Wanted to have a go at it and also wanted to paint the trays, so will give me a good finish to prepare for spraying. Got a lot of holes on the other plate to deal with.
Got lots of little bits to repair as I change things to my own preferences. Will post pictures as I go showing the new wiring and air system going in.
A good spot!servo wire glued to thrust pipe
Probably very wise move to redo everything else as well.
- Si_B
Simon
- Si_B
- Si_B
A slight ripple on the front board where there might have been a bit of excess resin under the cloth or a fault in the surface which I didn't notice. I did the first one stippling with a brush and the second with a scraper to spread the resin. The one I did with the brush looks much more consistent. Was worth experimenting with both as the surface will not effect anything. I could just leave them as bare wood.
Will get some paint and primer on later in the week when the weather improves.
Simon
- Thank you received: 14351
- Thank you received: 10743
He;s called Hornit Pilot on you tube the man is brilliant
Looks a nice model, we cannot fly ours until the middle of July and only then for 6 weeks, bloody birdy people
And 4 of them im in the uk
- Si_B
I've seen a few different methods including using little foam brushes. I had ordered some but they arrived today (too impatient). It only has a ripple in a small area, I'm being quite picky and it's not called a learning curve for nothing. I can see that I was just a bit too generous with the resin assuming the peel ply would sort it. I'm happy for my first attempt.
Been working on the wings today. Same issue with the servo blocks. These had an added screw, but once that was taken out you could just break them off with no effort.
Now expoxied on so going nowhere.
Simon
- Si_B
- Si_B
All servo connections are shrink wrapped so they should never need checking. The retract is now back in and I've gone over the covering with the sealing iron to get rid of some wrinkles and handling marks which were already there.
Now to repeat the process on the other wing.
Simon
- Si_B
- Si_B
Retract valve and all the airlines are in place. Front retract is back in as well.
Got to get the trays painted so I can mount the electronics and start connecting things up. As normal, most of the wires from the turbine are too short so a bit of wiring and soldering work still to do.
Simon
- Si_B
Will still look smart when installed I think.
Simon
