- Thank you received: 14191
Pilot RC Dolphin
- Si_B
- Thank you received: 680
Think next time I might pay to get the colour matched and put into a can. Will look okay it think, if not it can be easily sanded off.
Simon
- Si_B
You can see the ripple on the larger plate. Was going to use some finishing glaze to flatten it all off but decided that I was getting a bit carried away on what is just a tray.
However, the smaller tray which I used less resin on has a pretty flat and even finish. I'm actually really chuffed with the result and they look great in the model. Need to leave them for 24 hours to harden off then I can start the crimping marathon when I finish off all the connections.
Simon
- Si_B
Had to make a new turbine lead to reach the ecu which I've mounted vertically at the front on the left hand side. All the leads from the pump and valves reach without modifying.
Really need to pull the tank apart to double check everything and then get it mounted along with making the connection to the vent which I had to rework due to being mounted through the thin soft balsa skin of the fuselage.
It really is then down to finishing off all the extension leads and plugging everything in.
Simon
- Si_B
Tank secured in place and all the fuel connections made. Next job is to put servo connectors on all the servo leads and get everything powered up and plugged in. Technically all my building is finished. Need to go over the fuselage with the covering iron to tidy it up a bit and maybe a bit of thinned skinning resin in the nose wheel area to protect the wood from moisture.
Might get to fire up the turbine at the weekend, then she needs balancing and a test fly !!.
Simon
- Si_B
Got another power lead to route through from the Powerbox but the hole in the former is not big enough to let the mpx connector through. Easy tweak with the Dremel, but too late tonight.
Servos will be connected and assigned to the relevant channels using the Powerbox assistant. After fitting one in my Gryphon, I'm hoping this shouldn't take too long.
Simon
- Thank you received: 10615
- Si_B
Might try and plug it in tonight so will let you know.
Simon
Do you have to plug it into a computer
- Si_B
All powered up, just need to change turbine power lead to MPX connector as I've standardised on that for my turbines.
Got a busy weekend but hoping to get it all plugged together to test air system assuming it's not raining. Never seen it in on piece.
Simon
- Si_B
what a lovely looking aircraft.
bet you are well chuffed.
- Si_B
Got all the flaps set up and servos moving in correct direction. Also checked correct sense for Gyro even thought it will be switched off for first few trimming flights. Did the horizontal stabs at the weekend so just need to check air system for any leaks, cg and fire up the turbine.
Not got any free time now for the next week or so, so no maiden on the horizon just yet.
Simon
- Si_B
Simon
