battery help
- vmaxer
- Junior Member
09 Feb 2019 16:03 #16
by vmaxer
Replied by vmaxer on topic battery help
yes thats the one eric thanks , so i need a 4s 3000 battery and a smaller prop say 9x6
the rest went straight over my head:silly:
10 Feb 2019 09:35 #17
Replied by Eric on topic battery help
For a model that large, I'd suggest these items as a minimum -
Motor - hobbyking.com/en_us/propdrive-v2-3542a-1...outrunner-motor.html
Speedo - hobbyking.com/en_us/yep-80a-2-6s-sbec-br...peed-controller.html
Wattmeter - hobbyking.com/en_us/turnigy-180a-watt-me...-power-analyzer.html
Then look at the specifications, and get some props to match with the 4S battery.
Note - the motor is out of stock in the UK, and on back order for Global - that means there should be some on their way to the factory/warehouse very soon.
Don't forget - if you have too much power, you can throttle back, but if you don't have enough - - -
Thanks: vmaxer
10 Feb 2019 16:13 #18
Replied by Quorneng on topic battery help
Having re read my post my apologies. Clear as mud!
What I was trying to say was that you have to balance obtaining static thrust with a finer pitch for take off against a suitable pitch for the required flight speed. The faster the plane flies the worse that compromise becomes for static thrust.
When taken to extreme, as in the 1930's Schneider Trophy float planes, the fixed pitch props set for the 400+ mph top speed so compromised the static thrust that take off was pretty marginal despite having massive horse power installed in a lightweight plane.
10 Feb 2019 17:12 #19
Replied by Klipkopwildlife on topic battery help
The Italian entry never managed to take off, despite being the favourite! And, it was fitted with a marine propeller in the tail to try and get it some surface speed!
11 Feb 2019 03:18 #20
by one tenor
Replied by one tenor on topic battery help
Spits and Hurris had to be fitted with variable pitch props as their power was increased.Take- off was accomplished with fine pitch or they ran out of runway trying to reach flying speed. Ooops!! Sometimes sprog pilots forgot to their dismay.
11 Feb 2019 10:44 #21
To be fair part of the problem of lack of thrust on take off with coarse fixed pitch props was it slows the engines down so much they no longer produced maximum power let alone any inefficiencies of the prop. On the plus side slowing an IC motor down in this way (within reason) does not damage it.
On the other hand under the same conditions electric only suffers from the coarse pitch prop inefficiency as the motor will simply do its best to achieve normal full power revs regardless of load but will overload everything whilst doing it, hence the use of a Watt meter.
Time to create page: 0.428 seconds
