- Thank you received: 326
Its all so confusing!
- Dean M
At the minute i fly just i.c but i was wondering about having a go at an electric model or two, I have read many things on the internet about lipos, esc and motors but i find it all so confusing
First off I have got a GT Power V5 charger that I use to charge my Rx battries apparently it can charge lipos and balance charging or something!!!
This is the spec of it:
Operating voltage range: 10.0-18.0 Volt
Circuit power: Max 50W
Charge current range: 0.1-5.0A
Current drain for balancing Li-Po: 200mAh/cell
NiCd/NiMH battery cell count: 1-14 cells
Li-ion/Polymer battery cell count: 1-5 series
Pb battery voltage: 2-12V
Net weight: 280g
Dimensions: 130×80×23mm
Is this sutible for charging/balencing lipos? if so is there a limit on what lipos it can do?
Thanks Dean
I nearly choked on my latte.
Welcome to the world of electric flying
- Dean M
So am I right in thinking it would charge, for example a 4s 2000 mah lipo?
Oh and what is the difference between balance charging and normal charging?
Sorry for the stupid questions!!
(i keep telling myself there are no stupid questions just stupid people, or something like that
yes that will charge a 4s lipo.
i balance charge all my lipo's.
- admin
- Make it count!
a 4s lipo is made up of 4 cells.
its possible the cells could become unbalanced and have a varying voltage each.
The charger for example would find cell one full, switch off the charge to that cell, but continue with the other 3.
Correct me if i am wrong guys.
Yes the charger will cope with the lipo you suggest.
The info that Mike (Admin) has given you, is quite correct.
The reason we balance charge is so the charger can constantly monitor the individual cells and keep them balanced. If you just charge the whole pack, without balancing , should one cell get to full, the charger will switch off and may leave the other 3 cells not fully charged, hence not a fully charged lipo.
The only stupid question is the one that isnt asked, and should be
- Dean M
And 3s = 3 cells, 4s = 4 cells etc. is that correct?
Now for another one, in simple terms (cause i am a simple guy
Dean
The answer to both your questions are yes
You are getting there!!
- Dean M
standby..................More questions to follow.
Thanks Dean (Electrical expert
you ask the questions and i will learn something for a change.
