Futaba 14SG
I need to get on with the programming of this thing! To tell the truth I'm struggling! I would have thought that most Futaba users would be English speaking, yet the manual is just awful!
Once you've programmed your name in, the next thing is to Link the RX. The TX and RX must be within half a metre, then switch on the TX, go to link in the system menu and start the link process. When the TX starts to chirp, switch on the RX. When the link process is successful the unique ID number of the RX should appear on the screen. Finally, on the same screen select INH for Telemetry.
IMPORTANT, if you are using 2 RXs (to get the extra channels) each RX must be powered separately, you link the first one (channels 1-8 ) then only do you switch on the second one and link that. It would appear that even if you are using 2 RX in the plane, your switch on procedure must be sequential. ie, separate switches for each RX. I can see a problem there if you're in a hurry to commit aviation!
- Thank you received: 10722
And the touch dial thingy i dont like, i suppose it will grow on me like the JR did after the speky
All i can say at the moment is i have managed to switch it on
Also, if you change from say FASSTest to FASST, you must re-link the RX. Even if you put a new RX in the Revolver you will have to re-link and reset all your setting!
It's a learning curve BB, you must have a structured approach, I forecast that 2 months from now we won't be able to prise the TX out of your dead fingers!
Did you know that apart from being able to set Stick tension, you can also set the speed at which the sticks return to centre?
Still no to sure of that touch control, if i am touching the transmitter with my hand thats working the touch control it will not work, sat on the settee with it on my knees and could i hell as get to work, best on the table
Im going to try and download a kindle, i can get one foc on the internet my informant says ( a kindle must be something that allows you to read a book on the computer yes )
Just been looking i cannot find it, i do not like computers
That sounds ominous!
BB, a kindle is a portable electronic gadget a bit like an i-pad, designed to read books on. You can't download one for free, but you can download SOME books onto it, for free, once you have bought the kindle!
A Kindle is a proprietory book reader from Amazon, they cost about 150quid, but you can download a program to your PC that will allow you to read Kindle format files.
Re the touch control, has anyone near you got one of these capacitive pencils that you use on some of these tablets? You could try one.
AND i have programed it to operate the SR71 on the servo moniter at least
The Tx battery seems to be holding up now, but i charge it on my Fusion charger
Had to move the sr71 yesterday for the benifit of some one else and put a big 2" round hole in it
Lost my modelling room now for good so not to happy at the moment
My brain must be getting fried
