- Forum
- Forum Categories
- Technical Stuff, Radio Gear, Electronics.
- Servo going the wrong way and now including multiple engine installation and operation on
- Inactivated User
REJECTED,
fiddly soldering on crucial components is not needed with the tackle we have today,
easier way is to use 1xhi-tec, and one by futaba servo, these go the opposite way, and looking at the data on each servo will provide a near enough match,
REJECTED
its a good way, and it works, but we found better, but this was the way of choice at first
use a reversing lead, NOT my favorite way, cheap non branded electronics that can have an effect on your airborne systems, we sent 2 back on the 118"B 25 before we got one that did as it was sposed to do, we found a better way,
REJECTED
and that is the JR matchbox, with this, you can get access to 4 servos, more with a Y lead, you can reverse, servo slow, alter the travel of one servo, these we use on a few aircraft with multi servo instalations, and are very very good,
100% APPROVED
Get a 9 channel radio, at the very least, folk say, why do i need 9 channels? well, its called mixers, and we, on our planes, even with matchboxes, would be lost without them!! we are flying the Dak 144" span, with all 9 channels being used, and 2x JR matchboxes
I hope this helps anyone thinking of having a complicated airframe, that needs many servos, or reversers, its knowledge we have learned over a few years,
- Inactivated User
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
Eric wrote: There's already a thread in here with this title, I think it last appeared around the middle of last year.
Well now we have another one
Am not ready to start doing electrics in the planes yet
- Inactivated User
Surely the simplest way it to reverse the servo direction on the TX or are we talking about two servo on the same channel that need to go different ways? (like for flaps)
- Inactivated User
The easy way, for me, is to mount the servo upright, and take the output from whichever side of the disk moves in the right direction!
OR - mount the servo on it's side. BUT with one facing in, and one facing out. You will find that both output arms move in the same direction.
It saves messing about with extra plugs and sockets, which are potential failure points.
Use simple mechanics, rather than electronic gimmicks!
For ailerons, of course, mount the servos both facing in or out, and the outputs automatically go in opposite directions
You often found that a 'reversed' servo centred in a slightly different location, as well, so if the output drive to the disk was a square, you had to slacken off the locating screws for the pot, and turn it slightly in it's socket, to re-align the servo.
Firstly, a big thank you to Alan for taking the trouble to start this after he saw the comments on live. This is exactly what I said a few days ago makes this forum unique. Peeps care.
Unfortunately the way the Lanc tailplane is designed, its impossible to use the mechanical way eric suggests, a way I would have gone ,and prefered. I had exactly the same prob with the elevators, and used a reverser lead for that, but now Alan has brought me up to date with what is available, this I will look into if he would be so kind as to post a link to these units.
I know there was a thread with a bit of info on it about this subject posted last year, and was first of all tempted to join this one to it until I looked through the old one, and I quite agree is was very sketchy, so leave that one where it is and this one carries on on its own merits
- Inactivated User
ANYWAY, i thought i would post the LMA way of doing things, one can go ones own way, if one requires,
- Inactivated User
- Inactivated User
- Sarah-Jane Smith
- Gone
alan cantwell wrote: GAWD, i reached a 1000 5 posts ago, and no one told me
LOL I never look at post counts, thats why- you are as bad as beardie hehe
We dont applaud novices, Beard is approaching 7000
Now , where are these links to the matchboxes etc ?????
- Forum
- Forum Categories
