OS Engines, do they have a problem?
12 Nov 2016 11:10 #1 by Klipkopwildlife
OS Engines, do they have a problem? was created by Klipkopwildlife
I always thought OS engines to be the class of the field, maybe I'm wrong!
Some years ago I bought a 'NIB' (new in box) OS FS-80. I don't remember from whom, however I always take NIB with a pinch of salt.
Being unable to resist a bargain I have bought many engines over the years, since infernal combustion engines have become almost a thing of the past, certainly in the UK. Anyway, to continue:-
A few days ago I was looking for an engine for a project in my collection, as I was sorting through I was turning each of the four strokes to make sure it was on top dead centre (tdc), firing. The FS-80 wouldn't turn! My immediate thought was, 'the bugger, he lied about NIB'! Hardly surprising since this engine dates back to 1982.
Obviously I needed to do something pdq. On removing the cylinder head I discovered what looked like brown glue on the top of the piston and liner. But still locked solid.
Then I removed all the securing screws for the front and rear casings, the front casing was still locked solid but the rear came away easily, all I could see was brown glue and corrosion! Obviously it had been run and then stored without any kind of after run protection!
So everything went into a bath of lacquer thinners overnight.
12 Nov 2016 11:17 #2 by Klipkopwildlife
Replied by Klipkopwildlife on topic OS Engines, do they have a problem?
The next morning this is what I found
I was also able to remove the front casing (with difficulty) and found this
and this
I then started to clean things.
12 Nov 2016 12:07 - 12 Nov 2016 12:38 #3 by Klipkopwildlife
First the cylinder head
The discolouration is where the brown glue was.
Next up, the main body
Whoa, wait a minute, there's no wear marks! Check the piston
No wear marks of any kind, this engine has never been run!
Last edit: 12 Nov 2016 12:38 by Klipkopwildlife.
12 Nov 2016 12:28 #4 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic OS Engines, do they have a problem?
I have bought two of them, both the 110 pumped, I would not buy another, both of mine disintegrated, and the were both just run in :ohmy:
And they never hit the ground that hard either :whistle:
12 Nov 2016 12:56 #5 by Klipkopwildlife
That's not good to hear BB
So we can scratch the urban myth that all OS engines are run before leaving the factory!
After cleaning, blow drying and treating with 3in1 all the bearings seem to run ok, I'm going to leave the small rust marks on the crankshaft and re-assemble.
My storage shed is dry but the temperature can vary from 5 to 50C. It would appear that the assembly oil used isn't up to muster if the engine is stored for a long period of time, in my case 34years. Do we have a right to expect OS to use an oil that is 'fit for purpose' I think the answer is yes! I know that I am about to embark on a re-oil of all my engines.
One also must ask, how many engines have been destroyed because the storage oil was not fit for purpose.
12 Nov 2016 14:11 #6 by Eric
Replied by Eric on topic OS Engines, do they have a problem?
It's a long time since I used i/c, but they were mostly OS. I can only assume that the engine had been 'lubed' with a methanol/caster mix, at some point.
Methanol, of course, is hygroscopic, and castor deteriorates into brown glue.
12 Nov 2016 15:13 #7 by old fart
Replied by old fart on topic OS Engines, do they have a problem?
I HATE castor oil, much prefer synthetic lube. :)
13 Nov 2016 04:16 #8 by one tenor
Replied by one tenor on topic OS Engines, do they have a problem?
Are you going to tell us how it runs ?
13 Nov 2016 07:57 #9 by Klipkopwildlife
Eric wrote: It's a long time since I used i/c, but they were mostly OS. I can only assume that the engine had been 'lubed' with a methanol/caster mix, at some point.
From the evidence this engine had never been run, so what was in there came from the factory, which I think is unacceptable.
At the moment all the parts are lubricated with 3in1, I'm going to re-assemble over the next few days and run it just for you John. :) . I don't normally run any of my engines until needed. During the time I was collecting bits and pieces for my retirement I went a bit over board and bought way too many engines! About 30 four strokes and about 30 two strokes, because they were bargains! Of course now I'm looking for a 60FS that will go in a 63" Eindecker arf. The supplied engine mount (the bulkhead is already drilled and fitted with T nuts) will take a 35.8mm crankcase, do I have a suitable FS engine? Do I hell!
  • Flytilbroke's Avatar
13 Nov 2016 12:04 #10 by Flytilbroke
Replied by Flytilbroke on topic OS Engines, do they have a problem?
As I am seldom less than honest i will say I am not surprised that this is not as pristine as a newly manufactured unit. Remember too that " Fit for Purpose" is a more modern statement and idea. I doubt that any manufacturer designed anything to be "as new" for more than a couple of years at the consumer level. Especially as who back then would accept anything not soaked in Castor Oil.
Right that said, I like how well you have worked at getting an almost antique engine into what looks like a running condition. I too, look forward to reading about it running. B)
Thanks: Klipkopwildlife, boz
13 Nov 2016 13:07 - 13 Nov 2016 13:29 #11 by one tenor
I just wrote a reply which vanished. So here goes again. Thanks Klippy . Lovely engine and good and clean after the thinners It does a great job. It even shifts baked on stuff, Wow though how close are those vlave seats If you would rather not run it don't do it on my be half. greyf37@sky/com This guy may have the engine you want Graeme Farmer if I recall the spelling John
P.S. Pattern on the piston is interesting. Is it some sort of knurling ?
Last edit: 13 Nov 2016 13:29 by one tenor. Reason: PS
23 Sep 2021 11:20 #12 by Klipkopwildlife
Here, squareflux, I did post a video of it running, I'll see if I can find that.
24 Sep 2021 08:56 - 24 Sep 2021 09:00 #13 by Rich griff
Replied by Rich griff on topic OS Engines, do they have a problem?
I have used 3 in 1 oil in the past, and merco mention its use in an instruction sheet for merco engines.
It does not mix very well with diesel fuel as the paw19 did not run until most of the 3 in 1 was ejected out of the exhaust.
I have been told 3 in 1 is slightly acidic but don't have any litmus to check.
I use mt afterrun oil these days, just like the old days, until I ran out of the stuff.
Paw instructions these days just say use oil.
The os valves, I assume they where free and not sticking at all ?
Last edit: 24 Sep 2021 09:00 by Rich griff.
24 Sep 2021 09:16 - 24 Sep 2021 09:23 #14 by Eric
In model rail circles, 3 in 1 is frowned upon, because over time, it dries out into a gooey mess, a bit like castor. It is also known to attack some plastics.
So - you have lubed your favourite loco with 3 in 1, and after a time it gets sluggish, so you lube it with 3 in 1, and - - - - it ends up glued solid, and you have to strip it right down and clean all the muck off!
On the subject of i/c engines - I have a (my last remaining glow 2-stroker) brand new never been run OS 61 (I forget the model number) Gold head rear induction engine circa 1970 that turns over by hand perfectly freely (disregarding the compression - and I can't take the plug out as I lost my spanner ages ago!), no goo, no sludge - so whatever OS are doing now, different to then, who knows?
Unfortunately, the box and muffler/silencer/strangler disappeared years ago, so a collector wouldn't be interested.
Last edit: 24 Sep 2021 09:23 by Eric. Reason: added a comment
24 Sep 2021 13:02 #15 by Quorneng
Replied by Quorneng on topic OS Engines, do they have a problem?
I would agree about 3 in 1. Over a really long time it can 'dry' into a hard to remove residue.
Synthetic car engine oil seems a better bet and I use it to protect the slide ways and bed surfaces on my machine tools from our notoriously damp NW UK winter atmosphere.
Time to create page: 0.599 seconds
