P51 Oops
I, on the other hand have not been flying, I want to maiden this
3 days ago it was windless but I decided to check the Wattage, I found the Lipo was sagging badly under load (30watts). Fitted a new battery and now I'm getting 120W for a 367gm all up weight. That 150W/lb, should be ok, now all I have to do is wait for the wind to drop.
These lightweight foamy Mustprangs are very nervous models anyway, and it seems that you are too, now!
I'd suggest you try the CoG under the second panel-line back on the wing - ie just behind where the 'legs' plug in, and try it there.
They are also prone to flipping over on landing (as was the real one!), sometimes breaking the prop, so have a few spares in stock!
Teaching granny, but don't forget to balance your (any) low-winger inverted!
With the elevator in that sort of position coupled with a flat board tail plane and what looks like a pretty thin wing could mean that as it speeds up it looses whatever pitch stability it might have had.
I may be in a minority but I am cautious about using expo particularly on a maiden. With unknown flight sensitivity there is a danger that expo actually achieves the opposite of what is intended. Little stick movement (being cautious) no reaction, a bit more stick (still being cautious) not much happens, then a bit of panic (it is after all a maiden!) rather more stick and everything happens.
If the plane is naturally sensitive then without expo the first application of just a bit of stick generates an immediate effect so no problem and you just don't apply any more!
If the plane does not naturally respond to the initial stick movement then there is at least a chance that the control surfaces are 'mild' and applying lots of stick in a maiden 'panic' will not result in anything too drastic leaving you free to crash in the normal way.
I like to use expo to 'tone down' known flight characteristics to make the plane 'nicer' to fly.
If it is that sensitive I need expo to effectively fly it then something is wrong with me or the plane or both!
Since the servos are in the forward half the position of the elevator is no indication. On launch the elevator was exactly neutral, as were the rudder and ailerons.
The decalage is a moot point since it's a pressed foamy, you get what it is.
This was my 8th maiden, the first 7 were all successful, with one exception where an elevator servo failed in flight while starting the landing phase, but all the trimming had been successfully carried out.
I have to add that this is my first 'park flyer', 'light weight', 'low winger' maybe there's something in that. We'll see after repairs have been effected.
- boz
- Thank you received: 1420
Klippy DID say he flew the Liberty first, to get his fingers going.
The repair is simple, she broke at the weakest point, the pressed in panel lines at the trailing edge, I'm just debating whether to let in two carbon strips inside the fuselage to improve the strength in that area.
You are not trying to tell us you are going to be defeated by a RTF foamy!
