Soldering
30 May 2019 21:37 - 30 May 2019 21:38 #16 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Soldering
I have got my alloy soldering sticks I'm looking forward to having a go with it
All i nead now is a flight home but i have been told I cannot fly after an opp for several weeks,.Is that correct
I was on the point of booking my flight 4 days after the op :(
Last edit: 30 May 2019 21:38 by THE BLACKBIRD.
30 May 2019 23:29 #17 by Quorneng
Replied by Quorneng on topic Soldering
BB
I suspect it is an airline restriction just in case there is a problem whilst you are in the air.
Of course you could always arrange a special 'medical' charter flight with a doctor present but I suspect it would cost a lot of zeros!
31 May 2019 10:41 #18 by Klipkopwildlife
Replied by Klipkopwildlife on topic Soldering
BB, the airline staff are trained to look out for people who look as though they might have problems during the flight. Since you will be only 4 days after your op to the lower abdomen I doubt you'll be able to walk properly upright. And won't be able too for several weeks!
31 May 2019 12:36 #19 by THE BLACKBIRD
Hi Klippy it's only s small op Now days, out the same day
Hmmm what if I ask for wheel chair assistance :evil:
Crist I need to get home,
Seem to have been here forever and my daughter in law has no more jobs for me to do painted everything in and out the house including the shed
And I hate painting
Sending me crazy doing nothing
31 May 2019 17:33 #20 by Klipkopwildlife
BB, PM sent.
31 May 2019 18:47 #21 by THE BLACKBIRD
I have taken this way of topic
Sorry
02 Jun 2019 19:26 #22 by Phil Wood
Replied by Phil Wood on topic Soldering
THE BLACKBIRD wrote: I have taken this way of topic
Sorry
I think the thread has already dealt with the original question, but it's a handy subject to keep going.
I used to repair electronic equipment for a living so I've done a lot of soldering in my time. :cheer:
It shocks me the number of people who are scared of soldering and say they're no good at it, so there's a couple of tips I'd like to pass on.
Firstly the iron. Buy an iron that is the right power for the job. A typical 30 Watt Weller may be good for soldering battery cables, but it will wreck a circuit board if left in contact for more than a second or two. These 70 / 100 Watt soldering guns (the ones with the trigger) are something I hate. They may have a good heat capacity, so will heat a large object, but they seem to take ages to get to the correct temperature and the temptation is to use them as soon as they melt the solder, you need to be patient and let them get really Hot!!!
Most of the work I do is on very small jobs, they need a small, very hot iron, they only have to come into contact with the joint for a fraction of a second, they do the job without overheating the component.
Avoid irons that have a plain copper bit, these corrode into a disfigured shape in very little time, especially if left on for long periods. My iron is often left on all day (and night when I forget it :woohoo: ) so I use a 17 Watt or 25 Watt Antex iron with a plated bit. These can be left on all day without corroding, but you must never clean them with anything abrasive, no files or sandpaper, just a wipe with a damp cloth or sponge. The 17 Watt iron seems to get hotter than the 25 Watt one and is great for really small tasks.
Our forum builder, my son Mikey Admin, came to me a few days ago with his big telly. it had an intermittent fault and kept shutting down after a few seconds / minutes, ...... but sometimes would stay on for hours. I soon tracked down the culprit to a dry joint on the Power Supply Unit.
He decide to take a picture of it to show his wife Amy, luckily I can now post it here.
This is the sort of job I do most of the time. For the inexperienced, the dry joint is the one with a tiny circular crack around the component leg. The cure is to use a de-solder pump to clean away the old solder and a simple 1/2 second touch with my Antex and some new solder. :)
Let's see if this thread goes anywhere, if you have any soldering questions or problems post them here and let's see if we can sort them out. ;)
Here's the simple faulty joint that nearly made Mike spend several hundred quid on a new telly. :woohoo:
Thanks: Klipkopwildlife, Flytilbroke, Quorneng, THE BLACKBIRD
02 Jun 2019 20:12 #23 by THE BLACKBIRD
Hi Pol nice to see you posting
How you doing, we never did get to meet at Bebington
How about silver soldering that was always something that I thought I could not do
Until I tried it
02 Jun 2019 22:49 #24 by Phil Wood
THE BLACKBIRD wrote: How about silver soldering that was always something that I thought I could not do
Until I tried it
That's something I've only tried once Tony. Many years ago I bought an old Tektronix oscilloscope that needed fixing. It was a big bugger and apparently very expensive in its day..... something like $25,000. It had a long row of joints set in what looked like a ceramic compound, and next to it was a little reel of silver solder and a warning label about not using Tin / Lead solder. ... That's the only piece of electronic equipment I'd ever seen with silver solder.
They may use silver solder on circuit boards now, but I've never had any trouble fixing them with good old fashioned solder. :)
02 Jun 2019 23:46 #25 by THE BLACKBIRD
I only tried it on my Buck Jungmiesters undercarriage
Never thought I would be able to to it
But it was so easy and now I make tools and other things
Very useful
03 Jun 2019 09:55 #26 by one tenor
Replied by one tenor on topic Soldering
I was about to suggest that one of us with the knowledge/ability should run a bit of a thread on soldering /brazing. Heck it almost happened spontaneously with Boz's Car.( A35 rebuild/repair) Either in one lump or a number of bites. I have done some of all types in my work but don't profess to be an expert but could offer hints and tips. What does everyone think. My literary skills may not be up to much but I could give it a go. Much of the detail is EXACTLY the same for all types.
Solder-up dept*** One Tenor.
OR>P. M. me with your queries to save boring the A*S of everyone else
03 Jun 2019 12:00 #27 by THE BLACKBIRD
I think that's a good idea John we all learn every day hopefully
03 Jun 2019 18:17 #28 by one tenor
OK! any volunteers or is it down to me? If I do do this and I make a bit of a c^^k up please don't shout too hard; Cause in words of a certain big fluffy green baby Vent bird (Orville) I will Cwy. I will I will cwy. So what's the answer? Do I give it a try Or leave it to someone else. I can't illustrate does that matter? No working camera right now. Do we need to vote? Or blimey do we need to vote on the need to vote.? LOL
03 Jun 2019 18:58 - 03 Jun 2019 18:59 #29 by Eric
Replied by Eric on topic Soldering
We need to establish a committee, to decide on a venue where we can have a meeting to decide whether to vote, and what the agenda should be!
Seriously, I've only done electronics soldering. I did brazing when I was at school, but that's ahem years ago! Silver, and gas or arc welding, is new territory.
Last edit: 03 Jun 2019 18:59 by Eric. Reason: exchanged a couple of words.
03 Jun 2019 19:36 #30 by paul d
Replied by paul d on topic Soldering
OT, you've got the job, congratulations!!! start at once?
For what it's worth I can weld, only arc and mig although I did have a little go at tig thanks to a kind fabricator when I was mucking about with F1 cars ( only lasted 21 years!!!).
Time to create page: 0.388 seconds
