HOBBY KING SOAR 40
07 May 2013 09:44 #1 by Ex-Member
HOBBY KING SOAR 40 was created by Ex-Member
Hello gents and Ladies.
I have just had a bang on the door and the kind postman has dropped off a model aircraft for me to build.
The box was well packed and arrived with no damage.
On opening the box we find a nicely packaged and very bright collection of bits.
I will be upsetting the nitro knights by doing an electric conversion on this one.
more to follow as the day progresses.
Tony.
07 May 2013 14:34 #2 by Eric
Replied by Eric on topic HOBBY KING SOAR 40
I have to agree, Tony, the parts are very well packaged, and nothing (usually) gets damaged in the post.
I hope the parts all fit and line up properly!
07 May 2013 15:09 #3 by Ex-Member
Replied by Ex-Member on topic HOBBY KING SOAR 40
had a trial fit today and all the bits go together well, so far.
not doing much to it until i have the motor and battery fitting sorted, then it won't take long to glue together.
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
07 May 2013 16:45 #4 by alan cantwell
Replied by alan cantwell on topic HOBBY KING SOAR 40
what was the final bill with postage oh great sage
07 May 2013 16:56 #5 by Ex-Member
£42.00 with postage o wise one.
  • alan cantwell
  • Inactivated User
  • Inactivated User
07 May 2013 17:03 #6 by alan cantwell
deal of deals, oh great assembler
07 May 2013 17:04 #7 by old fart
Replied by old fart on topic HOBBY KING SOAR 40
Tony B. AKA Blooper wrote: £42.00 with postage o wise one.
:ohmy: :ohmy: :ohmy:
What a fantastic price for a .40 size model, :cheer:
What is the wing section Tony? :)
07 May 2013 17:29 #8 by Ex-Member
semi symmetrical, 60" wingspan.
looks reasonably well put together.
will cost more to fit out than the airframe cost.
07 May 2013 18:25 - 07 May 2013 18:28 #9 by Ex-Member
well i took all the bits out, looked at them and put them all away again.
Fuselage, i need to sort out a battery tray for this, it will be a take the wing off to fit the battery job, by the looks of it.
Two wing halves, these are joined with a wood brace and glued together, the ailerons need fixing on as well.
Bags of bits and pieces.
So i glued the wing together and had an offer up.
not a perfect fit, but the glue has taken up any gaps between the wings and it looks to fit in the fuselage quite well.
Next job is to glue the ailerons on and then look at the motor mount and battery tray before i glue on the tail.
Last edit: 07 May 2013 18:28 by Ex-Member.
08 May 2013 18:15 #10 by Ex-Member
ailerons are on and working.
motor mount is made (not the greatest job)
i used the i/c mount and made up a ply former that was slid onto the i/c mount and then glued in place.
motor fits ok, just got this big hole in the top and bottom of the nose are where the i/c engine was supposed to stick out, might have to make up a couple of covers to fill the gaps.
the esc sits in the fuselage ok, needs a tray for it and then a battery tray.
be able to get the tail fitted tomorrow i hope.
09 May 2013 16:38 #11 by Ex-Member
Battery tray is in, i can just squeeze a 4s lipo in there.
here is where i need to make a cover.
wheels are all on, aileron servo is in and working.
tail fin is gluing at the moment.
complaints:- the canopy is very flimsy.
The method of fitting the clevis to the control horn is very fiddly, they use a separate pin that has to be fed through both.
i broke one control rod clip, they are very fragile.
thats it so far.
09 May 2013 19:10 - 09 May 2013 19:11 #12 by Eric
Replace them with decent clevises - before you fly it!
Last edit: 09 May 2013 19:11 by Eric. Reason: typo
10 May 2013 16:48 #13 by Ex-Member
well it is almost finished, just the throws and cog to sort.
a 4s lipo right up the front does bring the front wheel down, so it cant be far out.
10 May 2013 19:40 #14 by old fart
Looks good Tony. :)
Except for that ruddy hair drier thing in the front. :P :P :P [badass]
10 May 2013 21:22 #15 by Ex-Member
you wait till i put a hair drier in the sea fury. :P :P :P
Time to create page: 0.275 seconds
