Mick Reeves 80" hurricane
thank you.
need to sort out the pull pull cables and then re hinge them.
made up and fitted new wing mounting blocks, they are gluing now.
want to make the servo tray and battery tray next, then i can think about making the nose.
thinking about a full cockpit as well.
i should have checked better before i re covered it. twit.
so i have had to cut the tail off and will try to straighten it out, if it won't then it is bin time i think. not going to waste too much time on it.
shame really, i rather fancied a big hurricane for me.
- Inactivated User
- Fly-Navy
- Thank you received: 295
will let you know tomorrow evening gents.
- Inactivated User
i cut the tailplane off of the fuselage and trimmed the high side down and then re attached the tailplane.
jigged it solid and had a good measure while the epoxy started to harden.
it is now 3mm out of skew when viewed from behind (instead of 20mm) and 2.5mm out of line to the fuselage sides.
my only problem now is that the stern post is not vertical, the fin is though.
so my plan when it is all set will be to slot the rudder in place and build up one side and sand down the other until it is all looking square.
then i can re cover the tail end and hide any rough joints under the tail fairing.
phew, we are back on track again.
- Inactivated User
- Fly-Navy
John
if i had 4 stroke money it might have ended up with one.
but £25 for a motor and £18 for an esc is a lot less money than a 4 stroke. sorry.
- Fly-Navy
It will look great whatever way you go.
