- Thank you received: 1284
building landscapes for model trains and dioarama
- a4kskyhawk
i will start by the gear you can get from your local model shop or online.
in the photo there is a rock making kit, water fall or river kit, plaster cloth the same type if you break a bone and need a cast this is not hospital grade tho,different colored textures and some trees.
- a4kskyhawk
then using the Woodland Scenics plaster cloth real easy to use just get a container and put water in cut the cloth in to lengths and put in and then lay over when over lapping put it about 50mm over the other piece and rub your hands over it . it will look like this.
it is quick drying stuff round about 1/2 hour or less. the next part will be putting a fine top of plaster on.
When you mix the top-coat plaster, add brown pigment, that way any accidental chips don't stand out like white beacons, as they will be 'earth-tone'.
From experience, if you are doing a railway scene (for convenience say OO/HO), do NOT use OO size ballast chips, they are way too big, and look like boulders. Use the next scale down, ie N gauge.
- Thank you received: 10842
Interesting thread this one sky
Thank you
Tony
- a4kskyhawk
- a4kskyhawk
so here is the picture so be kind and tell me how it looks. and if i can do better.
- Phil Wood
Well it certainly looks like a rock formation to me.!a4kskyhawk wrote: so here is the picture so be kind and tell me how it looks. and if i can do better.
The question is, "does it look like the rock formation you WANT it to look like"?
If the answer to that is "No" then you can do better .... If the answer is "Yes" ... then great job.
We've got no way of knowing what you want it to look like.
Personally,??? .... I may have been tempted to airbrush in a few greyish areas ... but that may be the lighting & it's just personal choice.
- a4kskyhawk
- Phil Wood
Disregard my computer colouring, that could be wrong, but on this screen it looks like you've got a SANDSTONE mini mountain ... but the rocks that have weathered off it look like GRANITE ... I don't think this would happen.
I think you're going for the volcanic rock look & that is more likely to be a greyish mixture. ... If my screen colour is correct & the main body is like sandstone.... then you'd more likely find this where there used to be a sea bed millions of years ago.
I don't think you'd find the two rock types together.
Having said this, I stand to be corrected? ..... Pol.
- a4kskyhawk
- Phil Wood
Just had a thought, oddly enough you'd quite likely see the rock types the other way around. :lol:a4kskyhawk wrote: thanks poly its going to be blended in once it drys. but keep comments coming thanks.
You could easily have a rocky sea bed of sandstone & then get an eruption of grey volcanic rock sticking up out of that :silly:
I think it'll fine if you just blend it all in as a mixture.
- locky
- Junior Member
- Thank you received: 53
- Phil Wood
If there's supposed to be water at the bottom there (did I read that it was going to be a waterfall) ... then the rocks at the bottom probably would look darker if wet. :lol:locky wrote: Polyphilla nevers been to kiwi land .. if i look around here there would be examples of the colourings used ..the unwashed cliff face and a washed greywacky stone at the bottom ,.. possibly more a sea side setting or the bottom of a canterbury river bed but still a good observation by pollyphilla.
I'm a stickler for detail Sky, Ann nearly kills me for pointing out all the faults when she's trying to watch a film on telly.... it looks great mate, just get on with it & do it as you want it to appear. You are entitled to use some artistic license. :lol:
The scree slope would be at the bottom, unless it was a very fresh land-slip.
Volcanic rock (lava) is very black and shiny.
Pumice is light grey and very porous - it floats in sea water.
Other than that, it looks OK, Sky!
