- Thank you received: 1484
Fairey Gannet AEW3
- Ralpharr2001
nice one with the hinges sir.
going to b a beautiful model when it's finished.
- Skydanz
- Senior Member
Don
Sent from my SM-G925P using Tapatalk
The sky is not the limit... the ground is!
- Skydanz
- Senior Member
Ralpharr2001 wrote: Thanks Tony. There's loads of design issues to be sorted out so I will be calling on you guys for ideas, solutions and the occasional kick up the backside in those dark hours when its not going right. :woohoo: For instance the front nose leg reduces in length during retraction. Have'nt worked out how to do that and keep some suspension in the oleo. The Fairey Youngman flaps are going to be a real :evil: :evil: to sort out.
Just had a quick play with the radome parts to see how it goes together.
Here's the motor, contra rotating Axi. Ready to go in.
I believe the mains shorten as they retract too. Argh!
Don
- Skydanz
- Senior Member
For the record Ralph, I'm pretty good at making fiberglass molds. I was planning to make one for my Gannet. I believe it could be much lighter than a built up one. Do you think the cowl is pretty much the same on both versions? I'd be glad to make one for you.Skydanz wrote:
Don
Don
- Skydanz
- Senior Member
Don
Don
- Ralpharr2001
In answers to your questions:
Software was Autocad Delux 14 for initial tracing, layout and sizing then used Solidworks 11 for former and rib development and major construction method. This was then converted for laser cutting.
A fiberglass cowl would be awesome. The built up front that I have is very heavy. I did originally plan on making a plug and then moulding fuselages. But decided against that idea for various reasons but still a possibility.
- Thank you received: 10842
You should start another thread on your glassing, to help us mortals
Thanks Tony
Don't want to muck this thread up sorry Ralph
- Skydanz
- Senior Member
- Ralpharr2001
As Tony says more videos on this element of model building please!
Skydanz wrote: I apologize for hijacking this thread.
No apologies needed Don
- Fly-Navy
- Thank you received: 295
I used to think they were lovely aircraft and greatly underestimated. We lost one when he had to do a "Bolter" night flying one night, think he could not generate enough speed to keep airborne, three crew got out ok but very weird watching it sink and the navigation lights still blinking underwater.
- Skydanz
- Senior Member
- Skydanz
- Senior Member
- Skydanz
- Senior Member
Still no luck not sure what I'm doing wrong.Skydanz wrote: OK... Not sure why the video didn't post but I'll put the link here.
