- Thank you received: 10842
Tiger Moth
No good putting it where you think it should be only to fined it will not fit the cowl
Just my two cents
Which when offered up to the fuselage looks about right.
which frankly looks lost in the cowl
An OS 61 FS looks slightly less so. I was thinking about an old open rocker OS60 FS but when I ran it up it ran fine but sounded like a bucket of bolts. New bearings will be ordered but in the mean time I'll go with the OS61FS
It's not as big as I would have liked at 9ozs but everything seems to want to get in the way when I try and put anything bigger.
As I thought, A14 (the centre spacer) is exactly where I want to put the tank, but it is what it is! The bottom of the tank will be roughly on the centre line of the carburettor.
I can expect the 61 to use about .8ozs/minute, about 11minutes at WOT and nothing to spare!
The main former A14 sits exactly where I want to put the tank.
Having settled on the thrust line I've fitted the engine mount.
Next will be to fit the throttle servo, all these 'little' things seem to take the most time!
Looks a nice kit
Perhaps Tony was supposed to remove that half of that former, for an i/c model? (but that would leave the front very weak!)
You've missed nothing John, in the old days when engines were flat out or out of fuel, the fuel would drain into the carburettor, sometimes with disastrous results in an upright setup. In an inverted it didn't matter so much because the fuel runs straight out! We set the centre of the tank on the carburettor centre line and sent the model off slightly rich, knowing it would lean out during the run.one tenor wrote: But won't that position tend towards flooding the carb? I always understood that the carb should line up with the centre line of the tank. Is that right or have I missed something.
Then came mufflers and we could use back pressure to lessen the effect, it was still there but nowhere near as bad.
With RC engines we have an adjustable carburettor, and throttle cut so I don't expect too much fuel leakage while the model is standing, plus it's an inverted setup so any leakage runs out, not in.
Needed to know more about push rod exits and the like so I've put the rear decking on. I was going to put just one side on but, wouldn't you know it? I put the wrong half on first!
Now I can see what's happening I've worked out where the servo arms must come and put extra blocks in so the rod comes exactly in the centre of the snake. Once that was done I could drill the push rod holes so that, on centre the rod was close to the outside of the snake. Remember the rod is 1.5mm and the snake inside is 3mm so I've got .75mm to play with. I've fitted the servos and I get 75% travel in each direction before the rod fouls on the rudder snake and 90% on the elevator.
The snakes will have to be supported inside the fuselage.
The first attempt just broke! On this one I've softened the rod just a bit (heated it up to blue) and it's split the surface. I had to take the rod to full red heat and cool before I could get a decent bend. No I have not re-hardened the rod! It's only the last half inch and the servo will break out before the rod bends. In my opinion a 1.5mm rod on a model this size is way over the top.
