Winter build
16 Feb 2021 00:20 #76
Replied by Quorneng on topic Winter build
Paul
I should have noticed the wing in not central on its mount.
Done that quite a few times on my RC wing rubber banders and flown them like that. :ohmy: It always surprises me how little difference it makes, particularly when you have ailerons.
02 Apr 2021 11:23 #77
Replied by Eric on topic Winter build
What became of Crash's proposed DH Beaver?
Re my 100" e-glider, of which the assembly 'stalled'.
I wrote somewhere that I solved the motor (lack of) space problem by sawing a bit of the nose off, and making a new ply firewall, so that the motors I already have WILL fit!
That leads me into another minor problem! I can't find a centre section hub for a folding prop that is big enough to allow the prop to fold around the new nose-end!
I need one with 6cm between blade hub pivots, and will take 8mm blade hubs, but mounts onto a regular prop driver! (which is bolted to the spinning bell of the motor - there is no shaft!).
There's nothing even near in the Hobbything warehouse, nor any of the on-line UK retailers that I've tried, so far.
The crunchy-foam little Green-Air Mosquito - I'm still messing about with fitting the spar, without using gallons of epoxy or adding weight - to bond it to the material. So that has gone no further, either. I need to fit the spar before I can attach the wing to the fuz, then add the motor pods, so I can fit the ailerons and speedo's, which hide in the pods, but I have to run the wires before I put the wing into the fuz!
Conundrum!
[badass] :evil:
Conundrum!
[badass] :evil:
02 Apr 2021 21:44 #78
That was, of course, meant to say - aileron SERVO's and speedo's, which fit - - - -:oops:
- crash happy
- Thank you received: 1203
03 Apr 2021 07:30 #79
by crash happy
Replied by crash happy on topic Winter build
Eric wrote, "What became of Crash's proposed DH Beaver?"
Never got past the "thinking about it" stage mate. I got sidetracked with the Viggen's Mk1 & 2. Too many other projects on the go to contemplate starting it now. One to be revisited in the winter maybe.
Thanks: Eric, Klipkopwildlife, paul d
Time to create page: 1.254 seconds
