Precedent T180 Restoration
  • squareflux
23 Jun 2021 11:53 - 23 Jun 2021 11:57 #16 by squareflux
Replied by squareflux on topic Precedent T180 Restoration
Challenge accepted! :lol:
It'll be a learning experience if nothing else.
To be honest, I had it in mind that this might be something I couldn't complete. But I'd rather learn and make mistakes on this, than try to build a new kit and mess that up.
It was the same when I started making foamies, the first ones were rubbish, and the my build technique improved with every one.
Last edit: 23 Jun 2021 11:57 by squareflux.
23 Jun 2021 15:06 #17 by Quorneng
Replied by Quorneng on topic Precedent T180 Restoration
squareflux
Restoring a poorly built plane is about the most challenging exercise you can do as for each issue discovered you have to work out a method of how to restore it and then to actually do it to a standard better than the original. Each problem is likely to require a variation of a range of possible methods.
At least building a kit, providing you do it in the right order, each assembly operation should be fairly straight forward.
On the plus side when it is complete you will have gained skills that will prove invaluable for crash repairs! ;)
Keep posting. Will follow with interest.
  • squareflux
23 Jun 2021 19:49 - 23 Jun 2021 19:51 #18 by squareflux
Did a bit more work today.
I started cleaning the wing, that cellulose thinners really does the job.
I also cut away the control arm plates, and I'll need to template up the new servo mounts. I need to get some thin ply though, the model shop didn't have any. I think I've got some in storage that I used as firewalls for my electric foamies.
I then started tackling the tail. The 2 supports were epoxied on top of the covering, so came away fairly easily. But then revealed a worrying hole.
Which then was more worrying once I'd got the empanage off.
I think it looks repairable.
To strengthen the tail, I think I'll add a couple of extensions down from the rudder, and cut slots in the fuselage for it to slot into.
Last edit: 23 Jun 2021 19:51 by squareflux.
23 Jun 2021 19:53 #19 by paul d
Replied by paul d on topic Precedent T180 Restoration
Nice work...think I'd be tempted to make a new tail.
Thanks: Eric, Klipkopwildlife, squareflux
  • squareflux
23 Jun 2021 20:48 #20 by squareflux
I've sent off for the wing and tail plans. So I'll leave it for now and think about it.
I'm going to do the wing first.
23 Jun 2021 20:49 #21 by Eric
Replied by Eric on topic Precedent T180 Restoration
Poor thing is really battered!
I know the description of an old-time aircraft is a patch of air held in place by a few sticks - but that's gone too far - multiply repaired, by the look of it! The previous owner(s) must have been a really sea-rap builder/flyer! :evil:
  • squareflux
23 Jun 2021 20:50 #22 by squareflux
Yeah, I get the feeling if I'd just tried flying it without checking it out first, it would have landed in a pile of firewood :lol:
  • squareflux
24 Jun 2021 12:09 #23 by squareflux
I bought a load of ply and balsa today, and I was going to start making a template for the aileron servos.
But I think I'd like to use smaller ones that the standard size ones, as I think they'll be too heavy to have out in the wings.
So would the micro ones be enough, or would mini be better? The only other ones I've used are the 9g ones in foamies, but I think they'll be too small.
24 Jun 2021 12:44 #24 by Eric
Mini and micro servos - are you referring to the translucent blue ones that cost about £2 each?
They will be WAY too small for such a big model.
Have a look at the slim-line wing servos similar to Hitec HS 125 MG (thin metal gear wing)
  • squareflux
24 Jun 2021 13:42 #25 by squareflux
I was meaning this type
www.sussex-model-centre.co.uk/radio-equi...s-micro-servo-359574
The translucent blue ones are the ones I used in my foam builds, so I wouldn't use them in this.
But the standard ones in the T180 are L40mm x W20mm x H35mm and quite heavy.
24 Jun 2021 17:18 #26 by Klipkopwildlife
Replied by Klipkopwildlife on topic Precedent T180 Restoration
Definitely will be up to the job.
Thanks: squareflux
  • squareflux
25 Jun 2021 09:06 #27 by squareflux
paul d wrote: Nice work...think I'd be tempted to make a new tail.
The more I look at the tail, the more I'm agreeing with you. Once the plans arrive, I think I will do a new tail. Between the rudder strengthening needed, and the broker ribs, I think it's too much to try and patch it up.
  • squareflux
30 Jun 2021 19:03 - 30 Jun 2021 19:08 #28 by squareflux
Hi folks. I've started mocking up the aileron servo plates.
I've got some 3mm Ply. But I'm just wondering if it would be better to use 1.5mm instead?
I've not worked with it before, so I'm not sure if it would be too flimsy, and I should just stick with the 3mm.
Any advice?
Last edit: 30 Jun 2021 19:08 by squareflux.
01 Jul 2021 07:21 #29 by Eric
I'd use the 3mm - give the mounting screws something to bite into!
For such a tiny piece, the weight difference will be insignificant.
Thanks: Klipkopwildlife, Flytilbroke, squareflux
01 Jul 2021 18:35 #30 by Quorneng
squareflux
As Eric points out it is not the strength of the ply itself that is the issue. 1.5 mm ply would be plenty strong enough but it is how the servo is fixed onto it that is the limiting factor. Screws create a high stress point so the wood need to be thick enough to hold and distribute the forces into the rest of the ply.
Now if you glue a servo into a close fitting all round recess there are no stress points so just foam by itself will be adequate but it is a bit of a problem if you need to get the servo out again! ;)
Thanks: Eric, Klipkopwildlife, Flytilbroke, squareflux
Time to create page: 0.998 seconds
