Precedent T180 Restoration
03 Nov 2021 18:11 #316
by paul d
Replied by paul d on topic Precedent T180 Restoration
If your using exhaust pressure to the tank then it shouldn't be a problem apart from needing a good spin with the starter to build up pressure, you could always squirt a little fuel in the carb before hand or arrange some sort of choke lever.
03 Nov 2021 18:15 #317
Replied by Eric on topic Precedent T180 Restoration
Venturi access - it depends if you are planning on hand-starting, or using an electric bearing-masher!
Try a bit of copper tube, with a few bends in it, to see if you can prime the carby without drilling holes.
If you are using exhaust pressure to the tank, the electric whizzer would generate enough to blow some fuel through if you put a finger over the exhaust outlet. (Mind your fingers!) Give it a whiz without firing the plug, first, then try it once the engine is a bit wet.
Thanks: Klipkopwildlife, Quorneng, squareflux
- squareflux
- Thank you received: 328
03 Nov 2021 18:20 #318
by squareflux
Replied by squareflux on topic Precedent T180 Restoration
Great, thanks. That’s good to know as I was hoping to avoid cutting any more holes.
I do have a starter motor, but need to get a battery for it.
So far I’ve been hand starting the engine on the test stand, but I’ll use the starter from now on.
03 Nov 2021 18:35 #319
by paul d
If it starts by hand readily then I'd continue, as Eric pointed out electric starters do put strain on the bearings, a squirt down the venturi followed by a few ( exhaust) choked turns, before you connect the plug! should see it going.
- Flytilbroke
- Thank you received: 1987
04 Nov 2021 10:08 #320
by Flytilbroke
Replied by Flytilbroke on topic Precedent T180 Restoration
If there is enough access for a "fuel bottle spout ". No Glow connected, open throttle, tilt model as required to raise intake, prime, close throttle. Well I am sure you can take it from there.
- squareflux
17 Nov 2021 20:32 #321
by squareflux
Went to the club field last weekend, and had the T180 checked over. It’s all good, but didn’t get any flying as the battery wasn’t charge. Doh!
Also had the Rising Star checked, and it’s now ready to go. So hoping to get some flying this weekend.
Time to create page: 0.999 seconds
