- Thank you received: 10842
I was so dammed ill last night i thought i was on the way
It's a cross between a rowing machine and a bicycle, called a Weslo Cardioglide. (Look it up on the tube if you feel the need). After using it for about half an hour, spaced over a couple of weeks, she discovered that it wasn't lack of fitness that was her problem, it was lung cancer. Until then, she could never manage to give up cigarette smoking. She did, then - but it was too late. About two years later, she gave up breathing, that was in 2011.
- SimonC
- Senior Member
- Thank you received: 265
Are you taking Amlodipine? It has several different names.
It is prescribed for the relief of high blood pressure which it does by relaxing the structure of the blood vessels to improve the return blood flow.
One side effect is it can cause the flesh, particularly in the legs, to swell up in a similar fashion to water retention.
Particularly if you are taking Amlodipine it is best to consult your GP asap.
I was described it years back for high blood pressure resulting from Vasculitis a blood disorder that restricted vessel blood flow which damaged my kidneys!
And recently I have been diagnosed to have High-count Monoclonal B-Cell Lymphocytosis - which is almost but not quite Leukemia, it has the same trigger indicators.
Who said that being retired was the best time of your life?
Atorvastatin
Bisoprolol
Clopidogrel
Colecalciferol
Dapagliflozin
Finasteride
Furosemide
Glyceryl trinitrate
Lansoprazole
Mirtazapine
Ramipril
Ranolazine
Ropinirole
Tamsulosin
Tramadol
I then take ibuprofen 400 for the pain when it gets to much, like this morning trying to do a bit of work in the shed, had to give up in the end, thats why i sit doing this
- jon.in.swansea
- Thank you received: 1192
- Flytilbroke
- Thank you received: 1987
Been doing a bit of covering
Like i said a wing of many colours, covering is so expensive nowdays to waste any, there is red and blue on the bottom
Im looking at one for the glider 3542 1150 Kv 11x8 or 12x6 prop on 3s and on 4s 9x6 10x5
