- Thank you received: 680
PST Reaction
- Si_B
First thing to sort out was the turbine mount. Luckily the Jetcat mount is quite wide, so even though it doesn't look pretty underneath, it is well secured to the solid part of the mount. Again I toyed with the idea of trying to grind the ply mounts out and start from fresh, but the risk outweighed the gain and to be honest you can hardly see the mount (even less so when the turbine is in place). Managed to knock out most of the dents and creases in the heat shield, and I'm happy with the fit now.
Next thing was to pull all the plumbing out. Apart from the clunk, I've replaced all the pipes and fitted a new bracket to hold the shut off valve. Pretty easy to plumb this in as the pump and solenoids are in the front of the turbine, so just need to run a pipe off down to the noisey bit at the back.
Currently working on replacing all the install plates as these were hacked around and covered in a sort of grey spackle paint which people seem to like, but I don't. Loads of space this time, but all the batteries are tucked up the front.
Thats about it for the moment. All the retracts are out as I will start the plumbing from scratch, I also need to look at the front mounting rails as these are a mess and I want to get some strength back in there. Still waiting for my air tanks to turn up, but hoping this should be ready in the next few weeks.
Cheers,
Simon
- Si_B
The turbines are pretty simple, I guess the fun starts when something doesn't work. This is my only Jetcat, my other turbines are Wrens and I've been really happy with the support I've received when ringing with questions. I've had a few flame outs with my original Wren 54, but after tweaking a few settings it seems to be fine now. Had 4 great flights at Long Marston a few weeks back.
You learn a lot at the jet meetings as well. Everyone is helpful and there are loads of models around to have a good look inside.
- Si_B
- Si_B
Got the ECU and the twin rx's mounted. Most of the wiring loom is in, but will not start connecting up till the air lines are finished.
New mounting brackets made for the air tanks. Was only running on one before and it looked a bit battered so replaced with twin tanks to give a bit more air capacity.
Quick shot showing the plates installed. Covers a lot of crap underneath and makes the jet much much better.
Need to make a little bracket to mount the air valves on and then it's time to start plumbing in the retracts and see how well they work. Really hoping not to find anymore problems.
Cheers,
Simon
- Thank you received: 10842
- Si_B
Got the plate in for the retract and brake valve, so will need to let that dry. Might run some air lines tonight if I get time. Hoping to fly this in a few weeks.
- Si_B
- Si_B
Put both retracts back in, all plumbed up etc. not really worthy of a photo.
Got the rudder and elevator servos to check out and some air line connections for splitting at the wing join. Turbine is 4 bolts and one connector plus the fuel line.
Had a result today as I managed to find a replacement nose leg steering spring which is missing off mine (keeps nose wheel centred when retracting). Got my fingers crossed that it will fit.
Next big job is to refit the electronic plates and plug everything in. If my Sprint was anything to go by, I will take these out at least another 30 times!!
Then it's time to bolt her together for the first time and put some air in to test the retracts. I've had this for over a year and have only seen it together on the day I bought it. I have a picture somewhere, will see if I can find it.
- Si_B
- Si_B
Bolts all loctited and fuel line run the the shut off valve at the front.
Finished all the wiring to the servos at the back. Now time to plug everything in and he done air in the system to check over the retracts and brakes.
Cheers,
Simon
