For those of you with deep enough pockets
Boomerang Nano
  • Si_B
06 Jul 2014 11:10 - 06 Jul 2014 11:26 #1 by Si_B
Boomerang Nano was created by Si_B
All finished with my original Wren 54 from my intro.
After selling my Intro, this came along at the right price so decided to put it together. Has eflite electric retracts which I've never tried before, but another flier uses them in his Nano and they are fitted to his 4th airframe !!.
Not much space in the nose of this one. Got everything forward but it will still need some weight in the front (got to fill the header tank first as this will reduce this a bit).
Should be a good little model for the tight strip I fly my Sprint from, but still not sure I will keep it. Going to fit my camera to this one, will post back once the maiden is done.
Simon
Last edit: 06 Jul 2014 11:26 by Si_B.
Thanks: Quorneng, THE BLACKBIRD, blue123
06 Jul 2014 19:47 #2 by alan cantwell
Replied by alan cantwell on topic Boomerang Nano
nice combination, looks great, seen these fly off some small fields, how is the elevator controlled, i guess a singleb servo in the tailplane, if so, how is the wiring routed?
06 Jul 2014 21:05 #3 by old fart
Replied by old fart on topic Boomerang Nano
It's wired by an extension through the boom Alan. :)
  • Si_B
06 Jul 2014 21:36 #4 by Si_B
Replied by Si_B on topic Boomerang Nano
Yep, the wiring is in the boom on the left hand side. Made and braided all my loom before the wing was joined but when I put her together this afternoon I got a bit concerned when I was one connection short. It had just dropped back into the boom, but for a moment it flashed through my mind that I had wired it on the wrong side and all the hassle of pulling out the loom etc etc.
Simon
06 Jul 2014 22:44 #5 by alan cantwell
so, you use the room in the boom, to safely route the loom, nice on,
Thanks: blue123
  • Si_B
26 Jul 2014 18:52 #6 by Si_B
She flies!!
Only got one flight but no problems. Needed a bit of aileron trim, more than I would have liked, but apart from that she cruised around on half throttle.
Mixed too much down elevator with the flap which made the landing more tricky than it needed to be. Tried to trim it, but moved the wrong trim and shut the turbine down.......that's nerves for you!! Model rolled on a little into the grass at the end of the strip, but apart from some grass cuttings in the intakes, no harm done.
Will try and get some video at some point.
Cheers,
Simon
Thanks: THE BLACKBIRD, blue123
Time to create page: 0.995 seconds
