Park flier electric project, motor spec ?
  • Iant90
29 Jan 2019 22:11 #1 by Iant90
I have a small model basic 3 channel which I am converting from IC to electric.
Using two 9g servos a small RC, bought a 1450kv motor with 7x5 prop and a matched ESC.
Power rating with a 3s Lipo 11.1v is 160 watts.
So with a remodel reducing weight I thought I would get the all up weight to around 1.5 lbs.
However, doing a quick check the all up weight of the electric gear alone came to 1.25 lbs (used a 7.2v Nimh and 4.8v Nimh as a rough guide not got a Lipo battery yet, so that will reduce weight slightly).
The plane itself without any weight reduction came to exactly 1 lb.
So total weight came in at 2.25 lbs, even with weight reduction in the aircraft I reckon it will still be around the 2 lbs mark.
The specification for the motor says it's suitable for models between 1lb and 3lbs. However, I was led to believe a good rule of thumb is 100 watts for each lb in weight.
Would this be suitable for a slow flying trainer, or would I be better increasing the motor spec to 2200 kg, this produces 240 watts ?
29 Jan 2019 23:16 - 29 Jan 2019 23:18 #2 by Quorneng
Replied by Quorneng on topic Park flier electric project, motor spec ?
100 W/lb is a good figure to use and would give a reasonable performance but the "slow" part of a "slow flying trainer" really all comes down to wing loading and of course ones mans 'slow' is another's 'fairly quick'! ;)
For a gentle park flyer you should be aiming for a wing loading of no more than 10 oz/sqft which indicates the plane should have a wing area of 3.6 sqft. Is it that big?
As your motor is only going to give you 71 w/lb at your anticipated weight you could do with both shaving of some weight to keep a limit on the wing loading and achieve some 'spare' performance. The faster you have to fly the more power you must have.:P
On the positive side you should find a LiPo of the same capacity and voltage as a NIMh is about half the weight so there is a significant weight saving to be had there.
You could get a more powerful and heavier motor but then the slow flying bit may go out the window. ;)
The nearest thing I have to a conventional slow park flyer is a Hobby King Slow Stick.
It is slightly modified (surprise, surprise to save a bit of weight!) and tips the scales a 22 oz with a 2200mAh 2s LiPo giving a wing loading pf 6.8 oz/sqft. With a slow revving 9x6 prop it manages very well on 120W and has power to spare.
Last edit: 29 Jan 2019 23:18 by Quorneng.
  • Iant90
29 Jan 2019 23:45 #3 by Iant90
Replied by Iant90 on topic Park flier electric project, motor spec ?
It's approx 3ft wingspan x 6" although it's a foam wing covered in thin sheet balsa. I could easily cut out sections without losing rigidity and cover with solar film. Same with the tail I can re-design cutting some of the solid sections and fit support stringers.
The body has lots of scope for weight loss so I could potentially get the body wings and tail section down to 1/2 lb without losing rigidity.
The undercarriage adds a fair bit of weight so could use a lighter setup or do without !
Another option is rebuilding the wing from scratch using spars etc to reduce weight further.
Going to a Lipo 2s 7.2 v and using the BEC instead of a RX battery could reduce weight further. I reckon I could potentially get it to 1.75 lbs all in weight.
As I just want it initially as a basic slow trainer it might just be okay.
I can upgrade it to a bigger motor if I want a bit more speed.
29 Jan 2019 23:57 #4 by Quorneng
36 x 6 is still only 1.5 sq ft so even at 1.75 lbs (28 oz) the wing loading is going to be nearly 19 oz/sqft which would puts it into the "warbirds/racers" category so 'slow & gentle' it wont be!
30 Jan 2019 08:05 #5 by Eric
AS Quorneng put - wing LOADING is what controls flight speed, not model weight.
Weight x wing area is what matters.
Compare a Fournier motor-glider with an F104 Starfighter - which is faster? Which glides best?
30 Jan 2019 11:27 #6 by Klipkopwildlife
Replied by Klipkopwildlife on topic Park flier electric project, motor spec ?
I hate to pour cold water but, I don't think this model would ever qualify as as Park flyer, it would simply cover too much ground too quickly! What are the guide lines?
  • Iant90
30 Jan 2019 18:10 #7 by Iant90
Point taken the 1450 kv is ample if not over spec for the wing area of this model. I could change prop size and slow it down using an 8 X 4 maybe ?
I used the description wrongly apologies, my interpretation of a park flyer is a small model powered by electric. I wouldn't be flying this particular aircraft in an actual park. fortunately I have got a very large farmers field at the end of my garden (which is fallow at the moment, nothing planted) so that would probably suffice as somewhere to do a quick test flight. Would have to be hand launched though, ground is too uneven for a take-off and landings probably going to be bumpy as well.
30 Jan 2019 19:36 #8 by Quorneng
My concern is that with your expected wing loading you cannot slow it down it as will have quite a high stall speed.
A fine pitch prop will simply not generate sufficient thrust at the expected flying speed. A 7x6 would probably be better.
You may also find that you will need virtually all those 160W to simply achieve sufficient flying speed. Prop selection will be critical.
30 Jan 2019 22:49 #9 by Eric
Which is where the WATTMETER comes in, so you can match the prop loading to the motor, ESC, and battery! You cannot do it by ear, or with a tachometer, like with an i/c.
An under-loaded electric motor will just whizz around at it's designed max rpms, (the Kv number) and do nothing useful, it will not go any faster.
an OVER-loaded motor will keep sucking amps as it tries to get to it's designed rpm's, until something goes pop.
  • Iant90
31 Jan 2019 23:25 #10 by Iant90
According to the supplier the 160 watts was measured on the bench with a 7 x 5 prop using the 30 amp ESC supplied.
I have also made a slight error in the wing size, I originally guessed and from memory thought it was 36". I decided to measure and it's actually 41". I know unusual a bloke under estimating size, but it happens, my excuse is that its present un covered state it looks smaller.
I will get it repaired and re-assebled and add some pictures so you can have a look. If I have to change motors and prop so be it. It's just a winter project to keep me occupied in the cold months, the motor can be used on another future project.
01 Feb 2019 12:47 - 01 Feb 2019 12:48 #11 by Quorneng
Do suppliers always give the right numbers when advertising a sale?
It will pay to take the 160 W figure of your motor as being "indicative".
You can boost a motor's power quite truthfully by simply using a big capacity battery rather than one likely to be used for flight. There is less battery voltage 'sag' under load so the motor can see a bit more voltage.
As an example lets say your motor actually gives 140W on a 3s 'flight' size battery that is giving a realistic 10 V at the motor. This means 14 A will be flowing.
With a big capacity battery the motor could well see 10.5 V. The current is more or less proportional to the voltage squared. 10.5 squared is 110 whereas 10 squared is 100 so a 10 % increase. The amps will thus rise to 15.4 A. Watts are VxA so 10.5 x 15.4 = 161 Watts. Bingo!
Furthermore there is also a question as to whether the motor could sustain this elevated power level continuously.
The only sure way is to measure with a Watt meter for any particular motor/battery/prop combination.
I am not suggesting your set up will not work and there is nothing wrong with 'try it and see' but simply to be aware of the potential problems.
Yes, at 41" the wing loading will be a bit lower but 'not a lot'! ;)
Last edit: 01 Feb 2019 12:48 by Quorneng.
02 Feb 2019 13:30 #12 by Klipkopwildlife
Ok, I'm going to put my oar in here! First off, forget about hand launching with that power set up, at full throttle the propeller will be stalled and it's very unlikely that a hand launch will give enough forward speed. Where our problem arises is that we've moved from IC where we had a fairly narrow rpm band (not quite true but near enough) so thrust could be controlled by propeller sizes and speed by pitch. In this electric era motors can have a maximum rpm limited by its 'wind' or battery voltage, and we can control power just by changing propeller diameter and pitch.
My Funcub weighing in at 2.75lbs has a recommended setup of, 3s battery (11.7volts), 850kv motor, 30amp ESC and a 13x4 propeller. With this setup she sagged so low on hand launch that the undercarriage bounced on the ground! Flight was also very lazy but could be attributable to altitude (4,000'). On a wattmeter I battled to get much over 200watts. Moving to a 13x6 gave just over 300w and transformed her. Maximum possible rpm on this setup is just short of 10,000rpm which will give a theoretical top speed of 57mph.
In the case under discussion we have a 7x6 propeller turning at a possible 17,000rpm to give 150watts and a top speed of 96mph. Given that the propeller disc is 12.25"2 against the Funcubs 42.25"2. To double the speed you have to square the power required, I don't see how a 7x6 propeller can absorb 150watts.
Sorry Ian, I don't think what you've been sold is fit for purpose.
03 Feb 2019 13:32 #13 by Klipkopwildlife
My last post is not very coherent, I don't have the math to understand the physics behind it all. I had hoped that someone would start a fight in order that we can get some sense out of the problem!
03 Feb 2019 14:23 #14 by Quorneng
Klippy
You post looked coherent enough to me!
About the only thing I would ague about it a 7x6 stalling with a 1450 Kv motor on a 3s. I was hand launching just such a set up (150W motor) this morning with absolutely no problem but then its wing loading and all up weight are well below Ian proposed figures! ;)
Ian
Reading through your posts I would point out that the kV of a motor does not determines its power output but just the speed it will turn at for a given applied voltage.
The power of an electric motor, and even more so for out runner types, is largely determined by its weight. There is a fixed ratio between the weight of the copper wire, the iron bits and the magnets. The weight of everything else (mainly the shaft and bearings) is small in comparison. So the heavier the motor the more copper, iron and magnets there are to convert electricity into mechanical power.
I am still concerned at the wing loading you are expecting to achieve. Whilst 160W (if you can achieve it) is just about enough to fly a 1.75 lb model a wing loading of 16? oz/sqft will make a hand launch marginal.
Using an undercarriage, which adds both weight and drag thus raising the power to fly a bit further and you don't have much 'spare' to start with, so unless you have a long enough super smooth take off surface it may be no more successful than a hand launch.
If only the wing area was 2.7 sq ft instead of 1.7 for little or no weight increase! ;)
  • Iant90
04 Feb 2019 13:35 #15 by Iant90
Sorry I have not replied sooner its been my weekend off so my better half had me doing chores etc
Some very good points made by all parties and all very valid. Got to admit much prefer take off to hand launch, although I could use a folding prop and eliminate the undercarriage. Had a few mishaps in the past with fixed props on my glider so now stick to folding. However if I can source some lighter wheels and design a lighter undercarriage my stick with it. Fixed props always seemed to give me a better performance.
After some deliberation I have come to two opinions:
1. I can change the prop size to improve the performance. Going too large will be restricted by ground clearance with existing undercarriage, unless its modified. Or leave as a hand launch and use a folding prop ?
2. I could re-design the wing to provide a larger surface area, which was already one of my considerations based on info from an earlier post. This potentially would reduce the weight by going to a traditional balsa construction, rather than using the original foam/veneer wing.
Time to create page: 0.958 seconds
