JB Atoms
23 Oct 2017 10:24 - 23 Oct 2017 10:26 #46 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic JB Atoms
It is a brilliant thread, to see how a professional works, thank you Tony
My measurements go in half a brick lengths :S
Last edit: 23 Oct 2017 10:26 by THE BLACKBIRD.
23 Oct 2017 12:16 #47 by Klipkopwildlife
Replied by Klipkopwildlife on topic JB Atoms
To say I didn't like the supplied conrod would be an understatement!
While the piston/cylinder fit is still tight (very tight) on both engines the big end fit with the original crankshaft and conrod is very sloppy = badly worn.
This is the arrangement that holds the gudgeon (wrist) pin in.
Thanks: Eric, Quorneng, THE BLACKBIRD, boz, Squirrelnet
23 Oct 2017 12:40 #48 by Quorneng
Replied by Quorneng on topic JB Atoms
Klippy
I presume the gudgeon pin retainer is screwed into the piston?
23 Oct 2017 14:35 #49 by one tenor
Replied by one tenor on topic JB Atoms
Can't make a lot of difference can it Klip? As screwed insert comes in from the other side / front
23 Oct 2017 15:02 #50 by one tenor
I agree about the conrod Klip Not enough meat round the crankpin and too thin in the shank. I would leave it blocky with just enough taper or relief to clear piston skirt The sloppy fit is likely down to the metal stretching in the big end eye I think. Next thing would have been fracture.
23 Oct 2017 15:11 #51 by one tenor
one tenor wrote: Can't make a lot of difference can it Klip? As screwed insert comes in from the other side / front
I mean the induction hole in the shaft
24 Oct 2017 00:54 - 24 Oct 2017 01:12 #52 by one tenor
one tenor wrote: I agree about the conrod Klip Not enough meat round the crankpin and too thin in the shank. I would leave it blocky with just enough taper or relief to clear piston skirt The sloppy fit is likely down to the metal stretching in the big end eye I think. Next thing would have been fracture.
I meant to ask you would you replace the other Con Rod for me as well please? An ounce of prevention etc :evil: ;)
Thanks John O/T P.S. I thought of lapping the piston and cylinder by hand with drop of dilute metal polish. What do you think?
Last edit: 24 Oct 2017 01:12 by one tenor.
24 Oct 2017 18:08 #53 by Klipkopwildlife
Re the piston/cylinder fit, they used to run together so I'm thinking it's just residue that the cleaning process can't get off. I don't want to go anywhere near it with any kind of metal remover. I'm busy making a needle valve assembly at the moment I'll make another conrod when I'm done and have tested the engine.
Thanks: THE BLACKBIRD, boz
24 Oct 2017 18:10 #54 by Klipkopwildlife
Quorneng wrote: Klippy
Yes, and on the complete engine I can't get it out to make a replacement conrod!
Thanks: Quorneng, THE BLACKBIRD, boz
24 Oct 2017 18:13 #55 by Klipkopwildlife
The hole is now only half as long as it is on the complete engine, I would guess the crankcase volume is only 75% or less of what it was.
25 Oct 2017 16:45 #56 by one tenor
Gotcha :)
27 Oct 2017 00:59 #57 by one tenor
No worries I'll shift it . The other was a swine too...
28 Oct 2017 08:36 #58 by Klipkopwildlife
Well this is embarrassing! About 5 days ago I sat at one of my work centres and measured the original needle valve assembly. Then I drew it, selected a piece of 1.5mm Piano wire for the needle and went to my workshop to cut material. An hour later I could not find the valve or the wire! I'm still looking! In the mean time I have started trying to make a new valve, and learning all about drilling very small holes!
28 Oct 2017 08:57 #59 by Mike Rolls
Replied by Mike Rolls on topic JB Atoms
I know the feeling. I once had a 12" white plastic rule go missing in the workshop for months! Then I found it just like that - when, of course, I had got a replacement.
28 Oct 2017 13:28 #60 by one tenor
It's always in the last place you look isn't it/? I "LOST" 2 steel rules for a long time .Looked every where. Eventually turned up Stood on edge under the turned over edge of the steel tool box held in place by the other tools in the box.Meantime like you I had bought new Grrrrrrrr!
Time to create page: 1.200 seconds
