3D printing Widgets
What you do is, instead of having the filament direct from the roll to the extruder you pull of about half a metre through so that it coils above the extruder, because you're not trying to pull the filament any more it doesn't break, simples.
www.thingiverse.com/thing:5150262
First near the extruder and also near the spool. As it breaks with quite a "ping" I expect the shock of one going triggers the other.
As a result I have quite a collection of filament "pieces" each about a foot long.
Not found much use for them so far but I keep them just in case I do.
- jon.in.swansea
- Thank you received: 1192
And another for the printing / CAD folk. I noticed there was a video showing how to add surface detail to a CAD model to give the impression of rivets or hatches. Now the so-called rivets are sunk into the skin of someones engine cowl model rather than slightly proud as one would expect but the techniques for aligning such details with either a simple or a complex body. The video involves a number of steps but mostly takes it slow. If I was going to try this I would start with something simple to get the pattern of CAD interactions sorted.
Here is the link:
It seems the filament does deteriorate with time even when kept in a dry environment.
- jon.in.swansea
and columns) to alter both the form and internal attributes of 3D printed objects.
Simple example is a downloaded prop. It has an overly small shaft so in the slicer
add a modifier, in this case a cylinder body of the correct radius at the shaft position
and 'subtract' it. That sort of thin is widely used.
The site also showed more than a dozen other things you can do with that kind
of body - like have a different kind of infil or a different density, or a different number
of perimeters or base layers or printing temperature.
Mind boggling with some slicers you can take an imported STL and make it a modifier.
Ideas bubbling up - take a fuselage that has a gyroid infil and increase the
density near critical stress points or up the perimeters in a few critical places.
Or near where mounting bolts will pass. If and when I get my man cave in
Wales I am certain to explore this....
For those who can cope with YouTube here is the link:
Yes it is a very useful facility to locally alter the print attributes in a bigger component.
My only grumble is if you later modify the original CAD file you have to remember that a) it used a modifier, b) what additional characteristic were specified for it and c) what was the modifiers file name if indeed you did save it.
On one of my "test" props I did do this so the hub & blade root were "solid" with a specified bead direction but the rest of the blade had two stages of reducing infill %. It certainly made a lighter prop with very little reduction in stiffness but I was concerned at having "step" changes in its internal construction giving potential stress points.
For a less highly stressed component the use of a modifier is very neat process.
- jon.in.swansea
Is that rig set up as a pusher? If not, your prop is on backwards!
Also if a blade fails, it doesn't just fling sideways, because of it's blade-shape it will also fling forwards! (and they can/will travel a lot further than you think!)
Although this was with an i/c, a friend - no longer with us - had a nylon? prop fail when peaking up his carb mix. If memory serves, a .61 two-stroke, The thrown blade passed between his arm and ribs, passing through his coat, jumper, shirt, and vest - like a knife. It doesn't take much imagination to picture what might have happened if the blade had hit him!
