Blackhorse Travel Air
It ONLY affects the tickover, because as soon as you start to open the throttle, the barrel allows more mix in, bypassing the air bleed.
- Dean M
- Thank you received: 326
I nearly choked on my latte.
Unplug all the pipes, and have a good blow down them, then put a spare piece of fuel tube on the carb nipple, take the needle valve right out, open the throttle wide, and have a good blow down that, in case there's a bit of muck in the jet.
If that doesn't work, check that the carb screws are tight, where they hold it onto the crank-case, and check the case backplate screws are tight.
