Blackhorse Travel Air
30 Jul 2012 22:08 #31 by Eric
Replied by Eric on topic Re: Blackhorse Travel Air
Just a thought - is the fuel foaming in the tank, because of a vibration that stops when the model is in the air?
  • The Beard
31 Jul 2012 03:09 #32 by The Beard
Replied by The Beard on topic Re: Blackhorse Travel Air
Never had that happen yet its a new kit but I feel its engine tuning that will cure the problem.Do have a spare engine which may have to be fitted,no big job.
31 Jul 2012 04:52 #33 by Quorneng
Replied by Quorneng on topic Re: Blackhorse Travel Air
A long shot but as it flies ok once in the air could it be the bouncing on the take off run causes the clunk to bounce above the fuel level?
  • The Beard
31 Jul 2012 14:17 #34 by The Beard
Dont think so always ensure clunk has a good length of tube without fouling anything and first flights were fine,and our patch is fairly smooth gets rolled regularly.My priority is actually the tail wheel .It takes so much to get it to steer straight that I am unable to concentrate on the engine.Ive done the usual thing and held the model vertical for 15 seconds
  • The Beard
31 Jul 2012 17:11 #35 by The Beard
Ive searched around this morning and found some rear wheels 1 of which I hope will help the Travel Air go straight on take off
  • The Beard
02 Aug 2012 02:42 #36 by The Beard
So another trip to the field to sort the TA out 1st 2 attempts bit of tuning and checking and at the point of the revs coming up to take off it stopped again,Flew the Harmomn Rocket for a while.Only myself and Pete there and we get on really well so good chats,Pete decided to go so I thought I would give it another go.I decided to change the plug for an OS 6 and it sounded crisp and ready for action.Gave it the gun and off it went ,a slight hesitation and then away like a rocket.In the air it would rev much higher than the HR engine in fact the prop was unloading so a bigger prop is called for.An excellant flight ,the side wind affecting the model more than the HR.Came in to land but was more of a handful ,landed ok but the u/c fell off again.There is so little holding it on so more beefing up called for.
  • The Beard
02 Aug 2012 02:43 #37 by The Beard
The rear wheel was a total success.
  • The Beard
04 Aug 2012 04:51 #38 by The Beard
Ive strengthened the front part of the u/c mount today placing 2 corner pieces on and then replacing the underside with ply just to add so much strength but not to much,Just needs covering but the weather forecast isnt looking promising
04 Aug 2012 16:53 #39 by Garry Pollard
Replied by Garry Pollard on topic Re: Blackhorse Travel Air
It seems to be the failing of ARTF models, and i have reached the stage that when I buy a new one the first thing i do is strengthen the U/C mounting, no matter how strong it appears.
  • The Beard
05 Aug 2012 03:31 #40 by The Beard
Yes its pretty standard isnt it Garry,when they come out nothing appears to be there to glue to.
05 Aug 2012 04:45 #41 by Eric
If they bothered using glue, and not beetle spit!
  • The Beard
05 Aug 2012 15:01 #42 by The Beard
Very true Eric especially as the beetle missed.
  • The Beard
22 Aug 2012 01:57 #43 by The Beard
Had a really good flight with the Travel Air Sunday but when I went for a 2nd flight the wheel fell off,so it was fortunate it happened when it did.But I had landed and taxied it back to my spot so the nut must of only just fallen off .Found the washer but not the nut.
22 Aug 2012 02:01 #44 by Garry Pollard
Course you didnt, the nut was holding the TX :) :)
  • The Beard
22 Aug 2012 02:04 #45 by The Beard
Grrrrrrrrrrrrrrrr gonna get yur.
Time to create page: 1.098 seconds
