HobbyKing Estrella
  • DominicM
  • Vlogger for 'Essential RC'
16 Apr 2016 09:22 - 16 Apr 2016 09:23 #1 by DominicM
HobbyKing Estrella was created by DominicM
1.5m sport/aerobatic model from HobbyKing. Suits IC (.50~.56 2-Stroke, .60~.80 4-stroke) or electric. Going electric with this one.
Turnigy G46 Brushless Outrunner 670 KV G46-670
Aerostar 60amp electronic speed controller with 5A BEC (2-6S)
Turnigy 4000mAh 4S 30C Lipo Pack
Propeller 13x8
Plenty of holes in the balsa and ply for lightening the overall airframe yet it's all very rigid and looks like adequate glue used. Scheme has been applied very well.
www.youtube.com/c/essentialRC
Last edit: 16 Apr 2016 09:23 by DominicM.
  • DominicM
16 Apr 2016 09:24 #2 by DominicM
Replied by DominicM on topic HobbyKing Estrella
Tail feathers in place...
  • DominicM
16 Apr 2016 09:24 #3 by DominicM
Servos in the wings, ailerons hinged. Carbon horns epoxied into ailerons, elevator and rudder.
  • DominicM
16 Apr 2016 09:25 #4 by DominicM
Elevator and rudder servos in place with control rods into guide sleeves in fuselage.
  • DominicM
16 Apr 2016 09:25 #5 by DominicM
Push rods hooked up to elevator and rudder carbon horns with ball links. Underside of elevator just needs a touch up from a covering iron.
  • DominicM
16 Apr 2016 09:26 #6 by DominicM
anding gear assembled and attached. Servos hooked up to carbon horns on ailerons with provided push rods and ball links.
  • DominicM
16 Apr 2016 09:27 #7 by DominicM
Just motor and RX install to do today so can maiden flight tomorrow !
16 Apr 2016 10:37 #8 by Klipkopwildlife
Replied by Klipkopwildlife on topic HobbyKing Estrella
Looks nice, it says to me 'Spitfire'
16 Apr 2016 13:20 #9 by one tenor
Replied by one tenor on topic HobbyKing Estrella
Reminds me of a C/L job I built in the 60 's but not sure what it was. Phantom springs to mind so maybe that was it LOL but it's very nice all the same .I'd like one .
  • DominicM
16 Apr 2016 14:37 #10 by DominicM
Motor installed on the stand offs provided with the kit. Soldered leads up to the ESC.
  • DominicM
16 Apr 2016 14:38 #11 by DominicM
Receiver installed. Cables tidied up. Battery dropped in and CG checked.
  • DominicM
16 Apr 2016 14:39 #12 by DominicM
Ready for roll for maiden flight tomorrow...
16 Apr 2016 14:59 #13 by one tenor
Very nice Look forward to it .No pilot though Tsk Tsk [badass]
16 Apr 2016 15:38 #14 by Quorneng
Replied by Quorneng on topic HobbyKing Estrella
Structurally I always get a bit nervous with such long motor stand offs.
It would be that much stronger and lighter if the fuselage structure itself continued forward so ideally the motor back plate could be bolted directly to the firewall bulkhead.
16 Apr 2016 16:30 #15 by Eric
Replied by Eric on topic HobbyKing Estrella
As it is i/c or elec, the rearward firewall is to provide the clearance for an i/c. Don't forget an electric is a fair bit shorter than an oil-burner.
Time to create page: 1.266 seconds
