An EDF Concorde - in Depron.
I am not sure you are right about 3in1.
I believe it was originally marketed as a sewing machine oil intended to last for long periods. WD40 on the other hand has very poor long term characteristics.
A long chain automotive oil would be fine but I am not sure how well it would penetrate into the sintered bearing material so I judged it would likely need attention before the 'lighter' 3in1. Time will tell.
It looks (and sounds) quite impressive.
My first test shows it delivers just over 8oz thrust.
The extra weight of the fans, ESCs and a 3000mAh 2s will be about 5oz.
16oz thrust for a flying weight of 23oz sounds a better bet than 8.4 for 18 so it looks like I will have to order the extra bits.
These very high kV motors appear quite reluctant to start every time so the biggest problem I can see will be getting all 4 going at once.
I suspect 4 will just be a noise.
- CeeJayP
- Hi Peeps
- Thank you received: 833
cj
There are some videos on YouTube of them working but they seem to be with quite big motors which can probably handle the slight variations in commutation better then the smaller ones which just seem to stop.
I was rather expecting the two motors to make a twin sound (like you get with props) but expect there is so much other noise you just can't hear it
As I have no idea how to make such a complex shape I am rather making it up as I go along.
First the centre rib.
This will be the only rib in the entire wing and is in 6mm Depron to overlap the joint between the L & R wing skins. The wing had a 3% depth to chord ratio.
On the production Concorde the 'droop' on the inner third of the leading edge was significantly increased to improve the low speed handling.
The wing skins have been cold formed to approximately the right shape to match the 19 wing 'webs'. There are no spars as such.
The first 7 wing webs in place.
When the two halves of the wing are joined the middle section of the fuselage will be built above (and below) it.
The tail section will be built like the nose as two half shells but then permanently fixed to the fuselage centre section so the fin can be added.
At some stage 6 motor wires (and a servo lead) will have to be run through each the wing. :ohmy:
But all of this is a long way in the future!
- andy watson
- New Member
- Thank you received: 4
Lovely build though- I might have to have a play with depron when I get my new workshop.
- CeeJayP
- Hi Peeps
cj
It really comes down to how big is big?
Depron is a form of expanded polystyrene. Polystyrene itself is an 'engineering' plastic which has specific mechanical properties which are not that different to the cellulose that makes up balsa.
The biggest difference is in how their internal structures are arranged.
Depron has a much lower density and a lower strength to weight ratio but it is equal in all directions. Balsa's superior strength is however distinctly directional.
So if you can make use of Depron's lightweight characteristics with a structure keeps the stresses low by increasing the area of the load bearing elements the resultant strength to weight can actually exceed that of balsa.
Depron works particularly well as a monocoque skin in a fuselage that has a reasonable cross section. Its light weight allows a relatively thick skin to be used that will handle both the tensile and compressive forces with a limited internal structure. The result is very light and remarkable stiff however actually making such a thing can be quite involved.
Most wings on the other hand have by their nature a relatively high span to depth ratio so generate higher skin forces that are less well suited to Depron. This limits the maximum span to weight ratio possible without some form of reinforcement.
In most wing designs the bending stresses create forces far higher than the torsional ones so a simple spar can take the major part of the bending loads leaving the Depron to provide the twisting stiffness.
This is the strategy I have used on most of my conventional wings.
A low aspect ratio delta (Concorde) is rather a special case in that it has a lot of skin for its span so can go to greater spans before reinforcement is required.
In general a balsa/Depron mix will be lighter than using just balsa but I am afraid there are no hard and fast rules as it depends entirely on the details of the design.
I hope this helps.
- andy watson
- New Member
Depron is particularly suited for a model with a very big wing chord compared to its span- such as is found in many jets. It is less suited for a traditional prop driven wing where a spar is needed because the wing is longer and narrower. I had in my head a full depth depron spar, but from what you have said a balsa one (or possibly 2 very small ones with very thin spar webbing) would actually work out better.
Again, from your description, it sounds like as more and more people push the limits of what is possible with depron we are actually likely to see a move towards more composite structures as the limits of depron lead to replacement parts being made of alternative materials. I guess we are probably getting close to carbon fibre tubes as a skeleton with a depron skin- not something I have seen done.
Stephen (I think it is Stephen) I am guessing you mean my Vulcan. Still not flown. Lost all impetus to fly with the closure of the workshop trying to sell the house (don't ask- it's been a nightmare). It doesn't have the power to get off our field- I need to rig up a dolly.
