project for late 2014. Avro Shackelton mr3
25 Jan 2014 11:54 #16
by Ex-Member
Replied by Ex-Member on topic project for late 2014. Avro Shackelton mr3
well i have had a re think on this project, i have decided that 1/10th scale will be far to big and heavy and costly.
sooooooooooo i will be scaling it back to only 1/12th scale, this still gives a wingspan of 10', but importantly it will still give me nacelles large enough to take a 4s battery.
so with this in mind my first sketch will be binned. ( well i will use it to work out the hidden control fittings)
The topic has been locked.
25 Jan 2014 17:47 - 25 Jan 2014 17:51 #17
by Ex-Member
Last edit: 25 Jan 2014 17:51 by Ex-Member.
25 Jan 2014 19:56 #18
by The Beard
Replied by The Beard on topic project for late 2014. Avro Shackelton mr3
Your a very clever and very brave man Tony Bennett :woohoo:
- Modelflyer99
- Senior Member
- Thank you received: 200
25 Jan 2014 22:18 #19
by Modelflyer99
Replied by Modelflyer99 on topic project for late 2014. Avro Shackelton mr3
I am following this thread with great interest, should be a good build.
I stand in awe of skills good sir.
25 Jan 2014 22:56 #20
by Ex-Member
26 Jan 2014 13:20 #21
by Ex-Member
gone back to the nose sketch.
trying to work out how to build it.
i think i will do it in two halves, so it can be built flat on the table and then joined together later.
3mm lite ply keels and formers, 6x6 stringers and then sheeted with 2.4mm balsa ( or 1.6 if it will be strong enough)
all helpful comments and help accepted.
- Mowerman
- Thank you received: 139
26 Jan 2014 14:16 #22
by Mowerman
Replied by Mowerman on topic project for late 2014. Avro Shackelton mr3
Tony. been thinking of a model Shackleton for a long time, having worked on them for a couple of years. Just a couple of thoughts, the one at Newark ( which is one of the ones I have worked on) is a mk3 phase3 with the Viper jet engines in the outboard nacales,
the contra motors will require two ESCs each so if you include EDFs that comes out needing 10 ESCs, expensive!
Thanks: Ex-Member, Sarah-Jane Smith
26 Jan 2014 14:21 #23
by Ex-Member
yup.
expensive, but what the hell, i will have a year to save up for all the bits.
it will take me that long to draw up the plans. so no rush.
29 Jan 2014 19:45 #24
by Ex-Member
29 Jan 2014 21:51 - 29 Jan 2014 21:52 #25
by Ex-Member
Last edit: 29 Jan 2014 21:52 by Ex-Member.
29 Jan 2014 23:31 #26
Replied by Eric on topic project for late 2014. Avro Shackelton mr3
Same link three times, Tony!
30 Jan 2014 16:30 #27
by Ex-Member
30 Jan 2014 18:51 #28
by alan cantwell
Replied by alan cantwell on topic project for late 2014. Avro Shackelton mr3
What a SAD end for a proud aircraft, still, hopefully, someone may someday save it, where is it Tony?
30 Jan 2014 19:21 #29
by Ex-Member
some where in the usa.
i believe it has gone now.
30 Jan 2014 19:45 #30
Replied by Quorneng on topic project for late 2014. Avro Shackelton mr3
Thanks: Eric, Klipkopwildlife, Ex-Member, Sarah-Jane Smith
Time to create page: 0.698 seconds
