- Thank you received: 1484
Avro Vulcan build
- Ralpharr2001
The fuselage extends out to part of the wing. So the outer wing panels are removable which makes it easy for storage and transport.
There are a few anomalies in the design that do not follow the full size. The main undercarriage is in the wrong place, to close to the centre line, in front of the outer engine. Full size has it outside the outer engine. Elevator is the same size as the aileron. On the full size the elevator is much larger than the aileron. That's what I've spotted so far. I am not going to modify it to take EDF's but will leave it with the pusher props making is semi scale. Even so the undercarriage needs to be in the right place and the elevator needs to be the right size. I will change these which will require some rework of the design.
So started the build today. Joined the two main formers. These come in two parts due to their size and require joining. The wing tubes are 10mm aluminium tubing. I will use these as the guides to lay out the wing and ensure I don't build in any twists. These tubes are boxed in with balsa. In some formers there is a square cutout 25mm square to allow the tube box to pass through. Some formers have round holes laser cut in the formers for the tubes.However, the holes are 12.5mm and the ally tube is 10mm. Why??? First design error. So for me to build accurately using the tubes as the guide I had to 3D print some round and square adaptors.
These were then fitted to the formers, slid over the tubes and everything lined up. Well nearly. The outer rib is too far forward. So I recut the holes to get the rib to line up properly. Error 2. As i am going to move the undercarriage to its correct location this meant that some of the wing ribs would be moved from the wing and built onto the fuselage section.
So that's progress for the first day. So far the design leaves a lot to be desired, no tabs to align formers making the build simpler and more accurate. Those that are provided are in the wrong place. I'll crack on tomorrow and see what else crops up.
I would suggest that using printed guides in plywood for the ally tubes is no bad thing. I am pretty certain the wear/load characteristics of printed plastics is rather better than ply and they can also be made to give exactly the desired degree of 'fit'.
- crash happy
- Thank you received: 1203
The prototype motors seem like a good choice, as they can run smaller props than the T 4240 540 watt , giving more ground clearence. They are a lot cheaper too, but recommend 60A esc's . Still you are a way off from that choice yet.
- Ralpharr2001
Boxed in the wing tubes in the main fuselage. Rather than just boxes I made the sides the same height as the ribs to transfer the loads across the ribs into the skin.
I've started on the outer wing panels. Managed to build a right and a left wing first time!! [badass]
Had a play to see the size of it.
I added a false leading edge to support the wing ribs and provide alignment and ensure I didn't build in any twist. Well if I did it would be the same on both wings!! :lol: :lol:
On the face of it your wing tube boxes look stronger than the spars.
- Ralpharr2001
- Ralpharr2001
Then had to do the other side and get them to match.
Quite pleased with the outcome. Then added the nose formers and stringers. This is shown on the plan as the location for the battery. A quick calculation of the moments shows that the battery needs to go slightly further to the rear. So plan is to make the nose cone removable so I can either put the battery as per the plan or insert it from below behind the front nose leg through a hatch. If the battery goes where the plan shows I'm concerned that the weight will crack the nose off in a heavy landing. So beefed up the intersection between the fuselage and nose by changing a couple of the stringers with spruce rather than balsa. I may also add a couple of shear plates from balsa as an added measure.
- crash happy
- Ralpharr2001
There are benefits to both. A single battery is easier to manage, the fuselage is big enough to take a very large battery. Downside, if the battery fails then all thrust is lost. I wouldn't lose control as the avionics will be powered by a separate BEC from a separate battery.
Two batteries give redundancy for the BEC as I would power the avionics BEC from both batteries (dual supply), no separate BEC battery (less weight), downside if I lose one battery then I have asymmetric thrust which is not good on a delta (asymmetric thrust would be quite small due to the short distance between the centre line of each motor and also the very large fin fitted with a rudder), two batteries to manage and secure.
A few things to think about. Personally I prefer the two battery set up. I use similar on my competition F3A pattern plane although they are paralleled up, but management is now a routine task for me.
- Ralpharr2001
This is just one of the problems, the spinner, or the cowl, or both is/are not fit for purpose! I haven't started yet, I'm not sure I ever will.
