- Thank you received: 1484
Avro Vulcan build
- Ralpharr2001
- Ralpharr2001
- Ralpharr2001
- Ralpharr2001
Modified the bogies I got from Bangood. They were way to long but the idea was sound. So I machined up some new bogies slightly shorter and moved the pivot point forward by a few millimetres. This helped them hang properly so they looked scale. They don't tuck away completely into the wheel wells. I will put some foam in there so that the foam pushes the front wheels down lifting the back wheels up into the well.
Put some 3S batteries in to test the systems. Works fine. Nose gear steering has yet to be connected so keeps jamming.
So after all this success I fitted the new flight batteries to which I had soldered on new connectors. First battery ok, flight systems live. Second battery connected smoke eveywhere!! :woohoo: :woohoo: :huh: :huh:
Muppet here had got the + and - round the wrong way on the plug! Everything got hot in a split second but I managed to disconnect. How did that happen?? Well between first and second battery soldering up I had lunch. Came back without thinking just soldered it up. Not my finest hour!! Damage was two 60A ESC's, two retracts (nose and a main) and one servo. Expensive, stupid mistake but could have been worse a 4S 5000mAh battery has a lot of energy! Managed to fix the nose gear retract. Ordered new main retract pcb and fitted two new 60A ESC's. Sorry, I didn't have time to video the smoke!! I was pulling it apart so no time to grab the camera!! :lol: :lol: :lol:
Is the battery ok?
I would think the instantaneous current was way over the max C . Even if only for a couple of seconds such an overload can take the edge of a battery's performance.
In the 'U/C down' video you would be in for an 'interesting' landing unless the nose wheel castors readily.
- Ralpharr2001
So with no further excuses its was the maiden today. A good stiff breeze straight down the runway. One of the guys I fly with also built a Vulcan at the same time as me. So we tested both today. He tested his first and had no issues other than not enough elevator throw. His elevators were as per the plan.
Then it was my turn. We checked my CG against his and I was very slightly more nose heavy, so safe. Interestingly my CG was as per plan. My elevator throws were more than his, but more scale with a larger chord. A good long straight run and she lifted off very nicely, retracts up. Slight left roll and little nose down. I did not start with any reflex on the control surfaces so was expecting a little nose down. Set the trims and she was hands off. Very pleased.
A few things to sort out. Add reflex to the elevators and ailerons. Too much play in the undercarriage bogies so it wandered during the takeoff roll, nothing that cant be sorted with a little machining. Move the CG back about 15mm.
- crash happy
- Thank you received: 1203
Superb!
Presumably you have to be aware of a prop strike given how easily a delta can achieve a very high but still stable angle of attack.
- Thank you received: 10842
- Ralpharr2001
Yes BB props on a jet!!
bloody well done mate!!
