23 Nov 2011 17:16 #16 by Ex-Member
Right former F5 now cut only 2 more to cut. :P then we can go onto former F6
23 Nov 2011 19:16 - 23 Nov 2011 19:18 #17 by Ex-Member
formers going in
first stringer
Last edit: 23 Nov 2011 19:18 by Ex-Member.
23 Nov 2011 23:00 #18 by Ex-Member
Yes it is. :P
Well after being sent upstairs again i have got this far today.
Stringers.
Stringers
Stringers
and yet more bloody stringers.
and i still have more to do. :(
Tomorrow we are back to cutting out formers. ;) ;) ;) ;) ;)
24 Nov 2011 15:23 #19 by Grumpy42
Replied by Grumpy42 on topic Hurricane Build Tony Nijhuis design
The mind boggles. In the time it has taken me to (part) build a fuselage and cut out a few dozen ribs Tony Has built a Piper Cub and is well along with the Hurricane! I might add that I had a head start because he was still building the Vickers 163 when I started the Fournier fuselage. Hey Tony do you take apprentices????? Wobbly OLD apprentices???:silly: :lol: :lol: :lol:
25 Nov 2011 00:15 - 25 Nov 2011 00:17 #20 by Ex-Member
slow day today, been cutting formers.
fuse 3
fuse 3 and fuse 2. :cheer:
fuse 3, fuse 2 and fuse 1.
fuse 4 still cutting formers.
need some more 3mm liteply as i am running out.
:P :P :P :P :P
Last edit: 25 Nov 2011 00:17 by Ex-Member.
25 Nov 2011 21:58 #21 by Ex-Member
well i have got nothing done today.
cut 4 formers and 2 sides thats it. :( :( :(
been outside gardening. :angry: :angry: :angry:
26 Nov 2011 02:38 - 26 Nov 2011 02:50 #22 by Ex-Member
the sum total of todays work.
i think i need to scrap the 3rd fuselage, i have a 1mm twist in one of the formers. :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry:
Last edit: 26 Nov 2011 02:50 by Ex-Member.
27 Nov 2011 04:00 #23 by Ex-Member
got a good book on the hurricane.
i can have floats
ski's
twin open cockpits
radial engine
biplane
sea hurricane
lots of different versions.
27 Nov 2011 06:17 - 27 Nov 2011 06:18 #24 by Ex-Member
Last edit: 27 Nov 2011 06:18 by Ex-Member.
28 Nov 2011 00:23 #25 by Ex-Member
slow day today i am afraid gentlemen.
i got fuse 4 front section stuck together and a few other little bits done.
28 Nov 2011 21:54 #26 by Ex-Member
i have managed to get a bit more done today.
ordered the extra wood i need to finish the builds.
this is fuselage 2 getting worked on.
fuselage 2 and 1 together.
things are slowly moving on. :cheer:
29 Nov 2011 22:43 - 29 Nov 2011 22:46 #27 by Ex-Member
well i have been stringering again today.
bent and fixed down the tailplane fairing and then stringering away.
stuck the firewall onto the number 2 fuse and started to curve the tailplane fairing.
back to stringers tomorrow.
then number 3 fuse can be got moving again. :cheer:
getting bored with cutting ply formers. :(
i weighed my ligthweight 90% balsa fuse and as it is now we are at 321gms
the no 2 fuse without the rest of the stringers is weighing 333gms.
so a fair weight saving so far.
Last edit: 29 Nov 2011 22:46 by Ex-Member.
30 Nov 2011 01:12 #28 by Ex-Member
little bit more done.
fuselage 1 and 2 together.
3 and 4 are still the same as earlier in the week.
30 Nov 2011 22:38 #29 by Ex-Member
well today i have curved and fixed down the sheet front of fuse 2.
also finished the stringers on fuse 2.
glued the keel on fuse 3 and 4.
Tomorrow i might consider finishing the formers for fuse 3 and 4, gluing F1 in one fuse and starting the stringers of the other one.
or i might just stay in bed. :P
01 Dec 2011 23:12 #30 by Ex-Member
last 3 bloody formers nearly done.
Fuselage 3 getting the stringers started.
I am getting fed up with formers now. :P :P
Oh joy it will be wing ribs to cut next. :unsure: :unsure: :unsure:
Time to create page: 1.810 seconds
