- Thank you received: 268
Lancaster restoration project.
- Firewood
- boz
- Thank you received: 1420
added the strengthening strip along above the bomb doors on each side.
fixed the broken former, was a bit like a vet with me arm stuffed up the inside of the fuselage.
still it is fixed now.
the broken tail section has been glued back and just need sanding.
also made a start on front turret detail.
oh i have also removed the rx switch that Garry fitted, as i did not like where he had fitted it.
stuck out like a sore thumb, i need to find a more discrete location for it.
plodding on as usual.
Unless the rx runs on a separate battery, you don't need one! :S
- Firewood
- Squirrelnet
- Thank you received: 2067
but we shall plod on regardless with it.
but thank you anyway
i can start the other side tomorrow.
now as the elevators need recovering i thought i would try sticking some silk over the tissue.
i am using diluted ronseal diamond hard floor varnish as a sealing medium.
the first coat of sealer has made it quite strong already, so two more coats will really strengthen the tissue.
sat down and worked out how many there will be on the fuselage when it is finished.
it works out at 3000 a foot, so 8ft long fuselage times 3000 = 24000 on the fuselage alone.
can't wait to do the wings.
covered the other elevator with silk today as well.
this has worked very well, they are now tough and still retain the fabric look.
So don't get carried away with the nylon covering! :evil:
just covering the elevators and ailerons with silk.
