Ian Middlemiss's Ferry 500 - Small-Field EFF Model
The formula is a 500mm maximum length and span (or 20" if you prefer) and an engine run of 8". The Club flies from Peterborough's Ferry Meadows, hence the Ferry 500 title. Club members have produced a power pack with two LiPos, a FET timer, motor and several props and a set of laser cut ribs and TEs. So, with such support, the project was too good to miss!
For more details, including the model plan, see: www.peterboroughmfc.org/technical-articl...8/E20Competition.htm
Here's the ribs, set in a block to check size and part sand away the laser burns:
The wings and tailplane were then laid down over the plan:
and after drying, removed, tidied and mocked up to check that the span was less than the maximum of 500mm! The two possible fuselage booms are also pictured, one being a 3mm carbon tube and the other a tapered fibreglass chuck glider boom.
General consensus is that the models need a DT, even with the space we have at Farry and the limited power run, so I'm experimenting with Radio DT for the first time. I'll report back on that when I have the system working...
- Squirrelnet
- Thank you received: 2067
(Or would that be too heavy?)
RDT - my main concern was one of weight rather than cost, but the system I'm trying out turned out to be quite reasonably priced:
HobbyKing Micro-Bec: £3.24 (3.4gm)
HK-5320 servo from HobbyKing: £2.92 (1.9gm)
Redcon CM421 4CH Rx from bangGood: £3.49 (2.7gm)
The weights are as measured rather than as advertised. That all adds up to 8.0gm. I could probably save a gram or so by stripping off the connectors I don't need and hard wiring the system, but we'll see as the project progresses.
The power system consists of a 2C LiPo, FET, Motor and Prop, all procured and supplied as a pack by a PMFC member, the whole weighing in at 34.5gm. This means that the model will be carrying a payload of at least 42.5gm, which is rather high for only 20" span, but we shall see!
Here's a pic of the electronic bits, with weights:
- Squirrelnet
Why buy a new radio set?
My Multiplex gear only works with Multiplex Rx's and the smallest is too big ...and £35.
I should look at getting a Spectrum TX or similar so I can use the cheaper rx's
Andy - 42g does sound a lot on a small model, and a lot more than a viscous Tomy Timer.
- Thank you received: 10842
Interesting project
THE BLACKBIRD wrote: Haaa do you think we will get the boss hooked on radio control :evil:
Interesting project
Ha ha....morning BB! You're too late on that one, I've been flying radio since around 1969....but I don't talk about it too much.
In a spare moment last night I drafted the pylon structure, fin, and prop protector:
I'm using Esaki tissue from SAMS Models with Deluxe Materials tissue paste as an adhesive. After laying the tissue over the pasted airframe, I rub the edge with my fingers dipped in tap water to seal them...the edges that is, not me fingers!
