cheap servo tester
25 Aug 2018 18:51 #1
by one tenor
cheap servo tester was created by one tenor
Have you seen how cheap these have become?[
/https://www.amazon.co.uk/BestDealUK-Tester-Consistency-Master-Checker/dp/B00B8MERS0/ref=pd_rhf_se_s_bmx_0_2?_encoding=UTF8&pd_rd_i=B00B8MERS0&pd_rd_r=66X5NM29JAPF7WKTFQYB&pd_rd_w=D8cM0&pd_rd_wg=nmSMo&pf_rd_i=desktop-rhf&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_p=294f6c5e-839b-4f3a-a750-a3df2bf35c67&pf_rd_r=66X5NM29JAPF7WKTFQYB&pf_rd_s=desktop-rhf&pf_rd_t=40701&psc=1&refRID=66X5NM29JAPF7WKTFQYBhttps://www.amazon.co.uk/BestDealUK-Tester-Consistency-Master-Checker/dp/B00B8MERS0/ref=pd_rhf_se_s_bmx_0_2?_encoding=UTF8&pd_rd_i=B00B8MERS0&pd_rd_r=66X5NM29JAPF7WKTFQYB&pd_rd_w=D8cM0&pd_rd_wg=nmSMo&pf_rd_i=desktop-rhf&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_p=294f6c5e-839b-4f3a-a750-a3df2bf35c67&pf_rd_r=66X5NM29JAPF7WKTFQYB&pf_rd_s=desktop-rhf&pf_rd_t=40701&psc=1&refRID=66X5NM29JAPF7WKTFQYBv
25 Aug 2018 20:19 #2
Replied by Eric on topic cheap servo tester
www.amazon.co.uk/BestDealUK-Tester-Consi...cy-Master-Checker/dp
... - did not match any documents.
Even with the extra / removed from the front!
Anyway, they're about £3 on E-bay! How cheap do you want it?
25 Aug 2018 23:24 #3
Replied by Quorneng on topic cheap servo tester
OT's link does work if you remove the initial /.
It shows a price of 72 p post free - which is pretty cheap. I paid 99 p for each of mine!
26 Aug 2018 03:57 - 26 Aug 2018 04:00 #4
by one tenor
Replied by one tenor on topic cheap servo tester
www.amazon.co.uk/BestDealUK-Tester-Consi...66X5NM29JAPF7WKTFQYB
Try sgsin 72p cheaper than Bang Good. Yep works now
Last edit: 26 Aug 2018 04:00 by one tenor.
29 Aug 2018 23:17 - 29 Aug 2018 23:20 #5
by one tenor
Re the above post see this one on same page--https://www.amazon.co.uk/Oyanor-Multifunction-Tester-Controller-Checker/dp/B01LJB1Y1W/ref=pd_lutyp_crtyp_simh_2_3?_encoding=UTF8&pd_rd_i=B01LJB1Y1W&pd_rd_r=c2d51e54-19a5-40a4-8e8c-2523a83d4772&pd_rd_w=aKu3g&pd_rd_wg=K5sGC&pf_rd_i=desktop-typ-carousels&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_p=e16539aa-11d8-41a0-a9f6-55106b7465e4&pf_rd_r=0AZ4CK64R20SBR55DKVM&pf_rd_s=desktop-typ-carousels&pf_rd_t=40701&psc=1&refRID=0AZ4CK64R20SBR55DKVM DAMN it didn't work but it was £ 5.99
Last edit: 29 Aug 2018 23:20 by one tenor.
Time to create page: 0.964 seconds
