- Thank you received: 38
Help with film covering
- Alan
- New Member
So to my question, can I use some kind adhesive with the film, if so what. My main concern is the white film as this will not adhere without some adhesive, but I am also concerned about how well the red film with adhere to the metal frame.
First off, I have yet to see any of these magazine 'kits' fly, so I would build it as a looking-at display model, not a flyable one.
As the covering material is 20 years old, it is likely that the - probably inexpensive - heat-activated adhesive has 'died' of old age.
Is there any indication of what it is/was, a brand name, or anything, either on the covering, or in the instructions? There are many on the market, all requiring different treatment.
Bonding it to the metal tubes - you will be very lucky! You would need to thoroughly degrease and clean the metal parts first, possibly with IPA or similar solvents. Any preserving oil or oxides on the surface will weaken the bond!
To get heat-shrink covering to adhere to such a small surface area would be difficult enough for an expert.
What are you using to bond the covering with? (a domestic clothes iron, a hair-dryer, etc?) The temperature is important.
As you are aware, metal is a good heat conductor, so to get the metal hot enough for the covering to bond to it will be a fine art, a shade too cool and it won't stick, a shade too hot, and the film will literally vanish into a molten hole!
Do you have any model-flying skills, yourself? If not, then that is another reason to have this as a display model only, or it will not last very long.
Weight and balance is critical - and with a very short-nosed WW1 aircraft - which was not easy to fly in the first place - getting enough weight forwards - (without adding any!) - and keeping the back end light, is a common problem. Being partly metal, it will be heavy enough as it is!
If you think of the full-size one, it had a huge iron lump on the front, and the rest of it was air-space held in shape by tiny tubes and sticks.
In the full-size world, covering fabric is stitched onto the airframe, but to do that in model size would be almost impossible.
Whereabouts in the country are you? Don't give away your street name, just the area - and I would advise you to try to find a local to you model flying club, where hopefully someone can give you hands-on guidance and assistance. Have a look on this site - bmfa.justgo.com/clubFinder.html - to see if there is one near you. You can zoom in to your locality.
Please let us know how you get on with it!
When you added your photo's, you missed a step out, when youj have 'added' then you have to 'insert' or you just get the thumbnails, as you did. Clicking on them gives the full image.
- Alan
- New Member
I can see the attraction of these weekly kits, but they are very expensive, this one cost close to £400 19 years ago. I can also see why many are started and never finished because the construction order dictated by the order in which that parts are supplied doesn't really work, the only way is to collect all the issues over a 2 year period and then start. And finally, never try to finish a model someone else has started, too many mistakes that are difficult to correct. The instructions aren't that clear in places and if you have no modeling experience it is easy to go wrong. I particularly liked how the trailing edges of the wings were glued on top of the ribs. It would have been quicker for me to build the wings from fresh than it is taking me to put them right. I think I can make it look something like, but it will be by no means perfect.
- jon.in.swansea
- Thank you received: 1192
- Alan
- New Member
It does make a highly detailed model hence the brass rod to emulate the full size welded steel tube used to make the fuselage of the full size. Quite innovative for the time when wood was the normal material.
Being a bit 'old school' I would consider using dope and a very light cotton fabric or heavy weight Model Span tissue rather than an iron on film. Possibly a bit more effort but it would be more representative of the full size covering.
I have a bit of a soft spot for the Triplane.
Much smaller, only 16" span. .
Do keep going with the pictures as you progress.
- Alan
- New Member
- Alan
- New Member
The trick is to tack one long edge down first, then gently pull the film tight, to remove any wrinkles, then tack the other edge down.
THEN you can tack one side down, and tease out any remaining wrinkles, tacking that down while you hold it taut with your third or fourth hand!
When all the edges are fixed, tack on the upperside (where you have wrapped the edges round and over.
When the film is firmly attached all the way around - THEN shrink the middle, careful not to heat up the edges again, or get it too hot, or you'll get an instant hole!
THEN you can do the same again, with the top side, doing it this way round means that the wrapped edge is underneath, more or less out of sight.
Radius's are tricky! You have to get a straight edge fixed, somehow, then tack the very edge around the curved surface - but do NOT tack it underneath yet.
When you have the film under control, cut slits in it right up to the curved edge, on the scrap side, then starting at the trailing edge, tack one of the 'triangles' down on the other side, trim almost all the surplus off, then do the next so it just overlaps, and tack that, - - work all the way around the curve.
It takes patience, determination, and practice!
If the film colour gets noticeably darker as you are doing it, you are on the verge of melting a hole. Either you are keeping the iron on the area too long, or it is too hot - which really amounts to the same thing!
That is a truly detailed model.
You mentioned that you had to reposition the trailing edge pieces as they had been glued to the top surface of the ribs. On the original the trailing edge was actually a wire which sagged under the tension of the shrinking dope giving the characteristic scalloped effect.
Just a point of detail but the trailing edge of the aileron lined up with the trailing edge of the centre section.
In the photo it looks like you lined it up with the centre section rear spar.
This is a period (1917) photo of the Triplane prototype before Fokker extended the middle wing a bit and added broad interplane struts to counter wing flutter.
It also shows how translucent the plain doped fabric was before the coloured dope was added.
I do hope your efforts with the iron on film come out OK..
- Alan
- New Member
DO NOT put it on here for all the world to see!
- Alan
- New Member
Probably a bit too glossy for scale but spectacular nonetheless.
The depression of the film between the ribs, particularly over the initial third gives a significant change to the wing section. You can see why Fokker used a rather unusual shaped ply leading edge skin fixed to the top of the spar in an effort to maintain the wing section when the dope covering shrunk.
Keep going.
ps Is that the Oberursel rotary that will go in it?
