Discus launch Gliders
28 Mar 2026 13:02 #16 by Eric
Replied by Eric on topic Discus launch Gliders
I see what you mean - but
That would reduce your acceleration arc to about 100 degrees, instead of 360. Beyond that, you are throwing the model downwards!
It is also another bit of kit you have to carry about. The whole point of Discus launch is there are two items you need,  a radio and a model - nothing else.
01 Apr 2026 17:29 #17 by Eric
All set up and ready to go, everything working in the correct directions. Had to add a bit of church roof to the nose to get the C of G right.
Looking at it looking at me, I thought t looked a bit like an eel's head, so I dug out my acrylic paint pens, and gave it two nostrils, and two eyeballs. Now I'm trying to get the 'rattle-balls' in the blue and gold pens, to unstick, so I can finish off.
I've shaken them til my arm aches, I've bashed the two ends on a solid surface, etc etc, and can't shift them yet!
02 Apr 2026 11:28 #18 by Eric
Trying my ultrasonic cleaner on them now, to see if that will get them moving!
02 Apr 2026 21:20 #19 by Eric
Didn't work either. New ones en-route.
10 Apr 2026 13:18 - 10 Apr 2026 13:19 #20 by Eric
Just checking and testing, hopefully ready for Sunday, and fiddling around trying to get all the wires in, decided to shorten the rx to battery via jst lead, for a better fit, and in unplugging the wire - I managed to pull one of the antenna wires off!
No prob, I'll just solder it back on - -
but I can't, it's one of those micro coax plugs and sockets!
Quick range-check with only one antenna, and it seems to work. I doubt I'm going to need a half-mile plus range!
Whatever, I've got a couple of spares en-route.
I've also given it a silly face, as I thought the bare surface looked a bit like an eel's head!
The silver of the pupils doesn't show too well on camera!
Last edit: 10 Apr 2026 13:19 by Eric. Reason: added a comment
Time to create page: 1.695 seconds
