Centuri Carbon printer
  • SimonC
  • Senior Member
  • Senior Member
07 Sep 2026 13:47 - 07 Sep 2026 14:34 #1 by SimonC
Centuri Carbon printer was created by SimonC
My Centuri Carbon printer needs a lid to keep the dust out.
Could have bought a version of the multicolour upgrade that included a big injection moulded lid but it raised the price 30%!
There are various self printed versions of a lid but they have to be in multiple parts that require a total printing time of over 24 hours and use up a complete spool of filament.
In addition if you want to be able to see inside they require acrylic panels to be added.
My model plane philosophy is to not print a complete subject but build using sheet (Depron in my case) and use printing to make small complex bits. Why not apply the same for the printer lid? Acrylic sheet panels cut to the required shape along with complex printed brackets and small nylon bolts and nuts to hold all the bits of sheet together. Lots of hours designing the brackets and cutting the acrylic (I have the time!) but only 25% of the printing time and use of filament.
Progress so far.
When complete it should simply drop into place in the same location as the original flat glass top panel.
Although my upgraded printer now has 4 spools which can be selected on command but so far I have not found how to insert a "change filament" command in FreeCad. I can select which one of the four filaments are to be used but only just prior to the actual "print" command on the printer. A true "multicolour" print is beyond my software capability at the moment.
Last edit: 07 Sep 2026 14:34 by Eric.
07 Sep 2026 14:49 #2 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Centuri Carbon printer
That fireplace in the picture is worth a few bob now days Simon
  • SimonC
  • Senior Member
  • Senior Member
07 Sep 2026 17:29 #3 by SimonC
Replied by SimonC on topic Centuri Carbon printer
BB
Yes  The house had been lived in by the previous occupants uninterrupted for 50 years so much pf the original Victorian fittings were still in place. The wood fire surrounds in both the reception rooms were one of the reasons we bought the house! They both took many hours restoration to remove countless layers of white paint!
Its original cast iron fireplace had been removed and replaced by a gas fire so I put one back in the correct style from an architectural salvage yard. 30+ years ago there were alot of cast iron fireplaces being ripped out in the Manchester area from the advent of central heating and North Sea gas so were plentiful. Not so much now!
By the way that printer was only on the dining table whilst I upgraded it. It was not long before my wife started asking why is it there?
It s now in my bed room alongside my old Anet A8 printer.
07 Sep 2026 18:19 #4 by THE BLACKBIRD
Yes i know in the 60s in ripped countless fireplaces out and installed baxi boiler central heating systems i contracted to the gas board for many a year
Thanks: Klipkopwildlife, jon.in.swansea, SimonC
  • SimonC
  • Senior Member
  • Senior Member
30 Sep 2026 17:01 #5 by SimonC
The latest hiccup with Multicolour upgrade to the Elegoo Carbon printer concerns the unit that guides the 4 filaments into the single heated nozzle.As I found out it is possible to get filament jammed in it so none pf the filaments can pass through. The printer is effectively dead!
Consulting Google it appears this is not an unknown issue.To cure it you have to remove the 4 PTFE guide tubes to get access. Elegoo web site even provides a downloadable stl file that prints the a tool which enables you to do this but it is not a lot of help when you need the tool because the printer isn't working.
Just as well my old Anet A8 still is!
The short piece of red filament was the cause of the trouble so now all is fine.
01 Oct 2026 08:08 #6 by Eric
Replied by Eric on topic Centuri Carbon printer
Oh, the irony! Print a tool to mend your clogged printer!
Time to create page: 0.786 seconds
