Harmon Rocket
  • The Beard
29 Apr 2017 02:15 #16 by The Beard
Replied by The Beard on topic Harmon Rocket
one of my difficulties is I often work late so by the time im ready to work on a model its to late.But last night I was able to get the 4 fuselage servos fitted.The Harmon Rocket is one of a few models where the rudder and elevator servos fit at the back of the fuselage.It has 2 for the elevator.I had to modify the servo holes to get the servos in quite time consuming.Tonite Ill fit the horns and rear wheel .Following that will be the aileron servos
29 Apr 2017 09:07 #17 by Eric
Replied by Eric on topic Harmon Rocket
Do they go in the tail as well?? :evil: Must be cramped up in there! :P
  • The Beard
29 Apr 2017 12:18 #18 by The Beard
yes Eric 2 one side and the other opposite so very close
  • The Beard
29 Apr 2017 12:21 #19 by The Beard
Ive used this method on other models with great success.Where on vintage models with a long fuselage the length of the control rod means very poor movement at the elevator or rudder so by connecting close to there is full movement
  • The Beard
01 May 2017 13:02 - 02 May 2017 16:34 #20 by The Beard
ive done the horns at the rear now next is the aileron servos push rods and the the tank
Last edit: 02 May 2017 16:34 by .
  • The Beard
06 May 2017 11:32 #21 by The Beard
the tanks all in now that was a game you have to bend plastic pipes and they melt to easily but done now
Thanks: , boz, Firewood
  • The Beard
07 May 2017 12:35 #22 by The Beard
the wing horns and push rods for ailerons are done now if Im home early enough may get it finished
Thanks: boz, Firewood
  • The Beard
08 May 2017 15:34 #23 by The Beard
last evening set the model up in the garden and had dinner on the patio with this fella
  • The Beard
08 May 2017 15:35 #24 by The Beard
Thanks: Eric, , boz, Firewood
  • The Beard
08 May 2017 15:35 #25 by The Beard
Thanks: , boz
  • The Beard
08 May 2017 15:36 #26 by The Beard
Thanks: , boz
  • The Beard
08 May 2017 15:37 #27 by The Beard
sc52 2 stroke
Thanks: Quorneng, boz, Firewood
  • The Beard
08 May 2017 15:38 #28 by The Beard
easy to ft the tank
  • The Beard
08 May 2017 15:39 #29 by The Beard
rear servos
Thanks: Quorneng, , boz, Firewood
  • The Beard
08 May 2017 15:39 #30 by The Beard
tonite I hope to fit the cowl and check the C of G
Time to create page: 1.255 seconds
