Harmon Rocket
Congrats, you have your flying pleasure back again, I am pleased for you.
- Away
- Flytilbroke
- Thank you received: 1987
- Grumpy42
The Beard wrote: If my theory is correct the reason I had to reset the tickover is it was revving to high.I think that was due to curing an air leak from the loose carb.If so it should go better.Hopefully I should find out later today,if I get any sleep and wake up on time.
Sounds like a reasonable assumption Stephen - curing the air leak would change the fuel air ratio.
